VIABLUE NF-S1 QUATTRO Double Mono XLR Modulation Cable 0.5m (Pair)
VIABLUE NF-S1 QUATTRO Câble de Modulation Mono XLR 0.5m (La Paire
4.4 / 5
By buying this product you get 30 loyalty points
Reference : 2497
309,99 €tax incl.
258,32 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
These double mono modulation cables with XLR ending reproduce the musical message with the utmost fidelity over the entire frequency range. They convey the sound with precise linearity and without staining or distortion .
The construction of the NF-S1 is ofsymmetrical type , that is to say that it comprises 2 conductors, each of them comprising 19 threads tinned 0.185mm diameter or a total cross section of 0.5 mm².
Specificity of the VIABLUE QUATTRO range, the quadruple shieldingis composed of 2 films in ALU-PETP (Polyethylene Terephthalic), supplemented with 2 inverted silver plated braids one with respect to the other.
This superposition of different shields ensures a 100% recovery and is particularly effective in high frequencies.
On the other hand, the NF-S1 take advantage of the XLR plugs of the famous series VIABLUE T6, which are characterized by their plated contacts 24k gold , and theiraluminum bodycombining strength and lightness.
Theferrites installed at the ends cancel interference that may occur on the cable surface. A final protection is provided by the outer sheath nylonexclusive "Cobra" VIABLUE, bringing the total diameter of the cable to <strong> 8mm.
https://www.audiophonics.fr/images2/4719_VIABLUE-NFS1-MONO-XLR_1.jpg
Characteristics :
  • 2 Conductor 0.5 mm² Consisting of 19 strands of Tinned Copper (19 x 0.185 mm) Silver plated
  • Insulation Polyethylene
  • Quadruple Shield " Quattro Silver Shield " (ALU-PETP & 2 Silver Plated Braids)
  • VIABLUE "Cobra" Exterior Protection Sheath Nylon Braided
  • XLR Terminals Male / Female Series T6s Gold Plated 24k
  • Total Cable Length: 0.5m
  • External Wire Diameter: 8mm
  • Capacity Between 2 Drivers: 50 pF (Core / Core)
  • Capacity Between Conductors and Shielding: 100 pF (Core / Screen)
https://www.audiophonics.fr/images2/4719_VIABLUE-NFS1-MONO-XLR_4.jpg
https://www.audiophonics.fr/images2/4719_VIABLUE-NFS1-MONO-XLR_3.jpg
Length (m)0.5
ShieldingYes
Section (mm²)0.50
ConnectorXLR
5 reviews
Qualité
Câble de bonne facture son plus aéré par rapport à des RCA !
This review has been posted for VIABLUE NF-S1 QUATTRO Double Mono XLR Modulation Cable 0.5m (Pair)
Bons câbles
Qualité de fabrication irréprochable.
Jacques F
Super pour ma troisième Cde délai de 15 jours respecté. merci
Jacques F
Pour le délai comptez plutôt un mois, ce n'est pas grave, il faut le savoir.
pour la qualité, c'est top qualité, pour mon installation c'est du très haut de gamme à prix doux
Très belle fabrication et très bon résultat cela comble mes attentes, en ce qui concerne le délai de livraison compté plutot sur trois semaines, ce qui n'est pas un problème il faut juste le savoir, l'attente est récompensé par la qualité de fabrication et la qualité audio.
Jacques
