1877PHONO DIRECT WIRE RCA Cable rewire tonearm "5-Litz-7"
1877 PHONO 5-Litz-7+ Direct Wire Cable recâblage bras de lecture
This 1877PHONO 5-Litz-7 + Direct Wire resetting kit has the particularity to be manufactured in one piece allowing the connection to your cell without any interconnection.
4.7 / 5
Reference : 7534
124,17 €tax excl.
Shipping date: 01-12-2021.
Orders placed before 11AM (GMT+1) will generally be shipped the same day (working day).
Shipping from France
Billing in France
Technical support in France
The materials and technology used make it a product of choice for anyone who wants to improve or repair tonearms.
Specifications:
  • Design: V-Wound ™ 33AWG
  • Conductors: copper (PC-OCC)
  • Conductor section: 4x 0.0255 (4x33AWG) twisted
  • Conductor type: Double polyurethane insulation, enamelled, color coded
  • Resistance to temperature: 155C °
  • Direct welding facilitated by the enamelled coating acting as a flux
  • Insulating tube composition: PTFE / TEF
  • Insulation: AL strap. Mylar + braiding copper shielding
  • Sheath: PVC
  • RCA Connectors: 1877Phono ZSP-4 24K
  • Weight: 24K Gold plated crocodile clip + OFC copper conductor
  • Outside diameter of the cable: 7.5 mm
  • Sheathed litz wires - sheath diameter: 4mm
Lengths:
  • From RCA splitter to Litz wires: 200cm
  • Total length of Litz threads: 50 cm
Detail of the connection of the wires:
  • Pair 1: Red / Green (Hot spot: Red)
  • Pair 2: Transparent / Blue (Hot Spot: Transparent)
    On some cells Transparent = White
https://www.audiophonics.fr/images2/7534/7534_5litz7_5.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_1.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_2.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_4.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_3.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_7.jpg
https://www.audiophonics.fr/images2/7534/7534_5litz7_6.jpg
Colissimo - TNT - SoColissimo
3 reviews
Câble phono 1877
Par encore installé mais en tout cas c est beau
Ça va le faire c est sur..
This review has been posted for 1877PHONO DIRECT WIRE RCA Cable rewire tonearm "5-Litz-7"
Câble phono 1877
Par encore installé. Mais en tout cas c est beau
Satisfait mais pas conquis
Fabrication qualitative.
Ce câble m'a permis de relier directement la cellule au prephono, il m'a fallu souder 4 petites cosses (travail d'orfèvre).
La platine (LE TALLEC) attend sa nouvelle courroie, donc je ne peux donner un avis precis, mais c'est plus délié et plus de bruit parasite... c'est déjà pas mal...
This 1877PHONO 5-Litz-7 + Direct Wire resetting kit has the particularity to be manufactured in one piece allowing the connection to your cell...
