Black Acrylic Case for Raspberry Pi 4 + Katana + Isolator V1.3
In order to dress and protect the trio composed by a Raspberry Pi 4, a DAC Katana, and the Isolator V1.3, Allo offers a specially designed translucent black acrylic housing. The latter has all the openings required to access the entire connector system and to dissipate heat correctly. In addition, the translucent appearance of the case allows the different floors of the system to be seen in order to highlight them.
This version of the casing is compatible with the Katana 1.2 (identifiable by its horizontal condensers on its surface).
The case is supplied alone. The Raspberry Pi 4, the Katana and the Isolator V1.3 are sold separately.
This product is only compatible with the Raspberry Pi 4. It is not compatible with Raspberry Pi 3.
Le boîtier est livré avec un film de protection marron. Celui permet d'éviter les rayures et traces de doigts pendant le voyage. Il suffit de le décoller à la réception pour profiter du design du boîtier.
Product type | Case |
Compatibility | Raspberry Pi 4 Allo Katana 1.2 Allo Isolator V1.3 |
Material | Acrylic |
Color | Black translucent |
