HIFIMAN Edition X V2 Planar magnetic Headphone Balanced High fidelity 103dB
HIFIMAN Edition X Planar magnetic Headphone Balanced High fidelity 103dB
By buying this product you get 129 loyalty points
Reference : 11365
1 290,00 €tax incl.
1 075,00 € tax excl.
Shipping from France
Billing in France
Technical support in France
HIFIMAN presents the newcomer of helmets "Audiophiles", the Edition X V2,successor of Edition X. Developed by the firm domiciled in New York, it surpasses once more the limits of listening to nomadic or sedentary Helmet.
The X Edition V2 is a radically advanced high-end version of its predecessors (ET-560, etc ...) and displays performance absolutely outof the common.
The technology used here is called Orthodynamique(orisodynamic), which has long been integrated into elite helmets but this time in a form even more evolved than ever, especially for the use of nano-materials in the design of the diaphragm.
Comparable on some points at Electrostatic Technology used by the tenors of the Audiophile helmets, this one allows to get rid of the dedicated amplifiers inherent to these manufacturers while maintaining a fairness of rendering of the same order.
The X2 Edition is comfortable on all types of music and sources, extended dynamic range . It promises to radically transform the current helmet listening.
Characteristics :
  • Diaphragms: High-transmission circuit Asymmetric
  • Impedance: 25 (+/- 3) Ohm
  • Efficiency: 103 db
  • Frequency response: 8Hz - 50kHz
  • Weight: 399 g
  • C3.5mm (1.5m) and 6.35mm (3m) jacks included in delivery
  • 6.35mm Jack adapter included
  • One pair of pads delivered
  • Delivered in its carrying case
-Full and detailed testing of HIFIMAN Edition X V2 by On-Topaudio -
Logo On-Topaudio
Hifiman Innovation Awards
Différence HIFIMAN Edition X / Edition X V2
(The X V2 edition has an improved headband design that can accommodate a wider range of head sizes and shapes)
(The editionX V2 has a yoke of metal now, which greatly contributes to increase the stability and durability of the helmet. That of the X Edition was plastic)
(The X V2 edition also has improvements in the ear pads, which are thicker and have a larger asymmetrical angle, which improves comfort)
(The X V2 edition has also changed its ear pad area that is in contact with the head. This material has changed from Velor to Polyester to significantly increase sound transparency)
