The Shozy Hibiki are in-ear headphones for high-definition listening while on the go or at home.
POINTS CLÉS :
High Definition
Shozy Hibiki IEMs have a unique design in their form: the combination of an ergonomic intra-channel design with carbon elements and a cable designed to ensure excellent audio performance and durability. In addition, Shozy brings another plus to the ergonomics of its IEMs by integrating a control box (volume +/-, play, pause) on the detachable cable, also integrating a MEMS microphone, compatible iOS and Android.
Hibiki earphones incorporate high-quality components and design. Thus, its carbon faces are polished by hand. The cable, designed to bring resistance, incorporates copper conductors and a control box with micro MEMS and the 2 pins connector is also made of copper. Finally, the Shozy Hibiki incorporates dynamic drivers of 10mm for an impressive rendition.
Hibiki comes with an Ethos Black 26AWG cable composed of 4 braided wires each with a TPE jacket to isolate the conductors from any interference. Each wire incorporates pure copper conductors for excellent conductivity. Similarly, the contacts of the 2-pin connector of the cable are also made of pure copper.
These In-Ear monitor have a high quality connector to replace the cable provided by another model with this connector.
Shozy Hibik unboxing by Porta_Fi
Driver | Dynamic 10mm driver, proprietary design |
Frequency response | 20-40kHz |
Sensibility | 102dB SPL@1mW |
Impedance | 18 Ohm @1kHz |
THD | <= 0.5% @1kHz |
Connector | 2 pins |
Cable | 4x pure copper conductor, TPE sleeve |
