BURSON AUDIO SUPREME SOUND OPAMP V5i Dual OPA Hybrid DIP8 (Pair)
BURSON AUDIO SUPREME SOUND OPAMP V5i - Dual AOP Hybrid DIP8 (The pair)
The Burson V5i is a hybrid audio AOP, integrating both integrated circuits and discrete components for exceptional performance. It bears the signature sound of its big brother, the V5, considered by many as the reference in the world of audio.
4.6 / 5
Reference : 13152
75,00 €tax incl.
62,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
BURSON SUPREME SOUND OPAMP V5i
Dual OPA DIP8 (Unit)
Hybrid Audio OPA with SSV5 DNA
Burson's latest PDO is the result of a partnership with a leading microchip manufacturer. So, with this alliance they created a new version of their V5 FET circuit. Moreover, in order to overcome certain limitations inherent in integrated circuits, they outsourced certain parts of their circuits and completed them with very high quality discrete components.
This V5i from Burson is the result of these collaborations. It is a hybrid audio PDO, integrating both integrated circuits and discrete components. In addition, it bears the sound signature of its big brother, the V5, considered by many as the reference in the world of audio.
Burson Supreme Sound Opamp V5i Double
Practical and Efficient
With this V5i, Burson offers a PDO similar in size to a classic PDO and also with DIP8 support. Thus, it will be extremely easy to integrate into devices that also have DIP8 support and its size will not be a problem. Despite its contained size, the V5i offers exceptional performance.
Incredible performance and quality
The V5i has a bandwidth of up to 50MHz. If these very high frequencies are not audible by the human ear, they participate in the listening of a piece to the general feeling and the richness of the restitution. And just like its big brother the discreet V5, the V5i offers dynamic, transparent reproduction and a wide sound image.
Will the V5i work on your device?
BEFORE INSTALLING AN OPA
In order to know if the OPA V5i will work on your device, here are some steps to realize :
  • Identify the PDO(s) in your device.
  • Verify that it is really an integrated circuit with 8 pins as on the picture below.
  • Note the model of the PDO(s) of your device.
  • Find pine 1 thanks to the semi-circle indicator (in blue on the picture below).
  • Determine if you need a single or Dual PDO.
Installation
1. Make sure you have the right PDO
  • V5 OPA-D = Dual OPA = can replace a dual OPA
  • V5 OPA-S = Single OPA = can replace a signle OPA
2. Connect the OPA in the correct direction:
Align the half circle of the PCB or IC support with the half circle of the V5i OPA.
An OPA connected in the wrong direction has a very high chance of being destroyed. An operating error is not covered by the warranty.
Compatibility
The Burson Dual V5i OPA is compatible and therefore interchangeable with the following OPA:
AD823, AD823AN, AD8066, AD8620, AD712, AD827, C4570, JRC4556AD, JRC4580, JRC5532, JRC5532D, JRC5534, LF353, LM4562, LME49860, LM833N, MUSES8920, NE5532, NEC4520, NEC4570, NJM2068D, NJM2114, NJM2214D, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832, BA15532.
ModelDual V5i
Connection typeDIP8
Dimensions11 x 11 x 7.3mm
Quantity;1 - Unit
Absolute maximum ratings
DescriptionMinTypMax
Supply voltage+/-5V / 10VDC-+/-16V / 32VDC
Operating ambiant temperature-25°C-60°C
Storage temperature range-65°C-85°C
DC Characteristics
DescriptionConditionsMinTypMax
Quiescent current--10mA-
Input offset voltageRS = 00.05mV3mV-
Input offset current-0.02µA2µA3µA
Input BIAS current-1.2µA3µA4µA
CMRR--100dB-
PSRR--90dB-
AC Characteristics
Open loop gain--70dB-
Open loop bandwidthRL = 600 Ohm-45kHz-
Gain bandwidth product@ 100kHz-50MHz-
Slew ratef = 10kHz, RS = 2 KOhm45V/µS-50V/µS
Input resistance--45 MOhm-
Crosstalk distorsionf = 1kHz, RS = 600 Ohm-> 95dB-
THD1kHz @ 2V, RL = 600 Ohm-0.005%-
Output impedanceAV = 30dB closed loop f = 10kHz, RL = 600 Ohm-0.5%-
OPA TypeDual
5 reviews
Burson
alles super geklappt, sehr guter Verkäufer, gerne wieder
This review has been posted for BURSON AUDIO SUPREME SOUND OPAMP V5i Dual OPA Hybrid DIP8 (Pair)
Great
Update asus sonar essence stx II with Burson v5i. Apart from a slight hiss with the volume at minimum which Burson claims is normal the sound with my Shure se 846 and Sennheiser hd 660 s is much improved. The distinction between bass is clearer, medium and high, even the soundstage is wider. A well ventilated case is suggested because the Bursons heat + the Muses. Recommended product, good service from Audiophonics
Burson V5i
Bons OP Amps... mais franchement, les OPA1656 font mieux et valent 4X moins chers ! Certes, les OPA1656 sont introubales en DIP8 mais avec une petit adaptateur le tour est joué )
Burson AOP V5i
Super AOP, il remplace dignement un OPA1622 dans un Ampli à base de TPA3251. Très bon équilibre dans tout le spectre, scène sonore très fine et détaillée. Belle séparation des instruments et des basses tendues à volume plus haut. Il est meilleur en tous points que le OPA1622 et OPA627. En revanche, ne fonctionne pas avec mon DAC à base de AK4497... donc je retire une étoile.
étonnant !
montés sur une carte audio asus XONAR STX, ils offrent un registre sonore naturel d'une grande beauté sans agressivité.
une belle réussite pour burson.
The Burson V5i is a hybrid audio AOP, integrating both integrated circuits and discrete components for exceptional performance. It bears the...
