BURSON AUDIO Supreme Sound SS OPAMP V6 - Discrete single OPA (A pair)
79,00 €tax incl.
65,83 € tax excl.
- AOP with discrete transistors mono in pairs-
burson v6 discret audio AOP
High resolution, dynamic, balance
The AOP Burson V6 ViVid and Classics are evolutions of the V5 series with a particularly good sound balance. They will bring opening, timbre, dynamics and sound image in three dimensions to any Hifi devices compatible with support DIP8 compatible NE5534 single or NE5532 dual according to the versions.
Improved design
Offering Improved heat protection and improved heat protection The discrete AOP Burson V6 are now also stable on the single stage stage buffers as on the I / V voltage stages of the DAC stages. The Burson v6 are thus of exemplary stability now equipped with 0.5% metal film resistors with two stages of hand-selected FET transistors. The version VIVID brings an additional definition, the classic version an extra stamp.
, font-weight: normal; "> font-size: 22px; font-family: Muli, Arial;REVERSE PROTECTION SYSTEM
A new protection system allows greater reliability of these high-performance discrete AOPs. The Burson AOP V6 are thus designed to survive any assembly accidents upside down on DIP 8 support.
  • Minimum Voltage Required: + - 3.5V / 7VDC
  • Maximum Voltage: + - 16.5V / 33VDC
  • Current consumption: single 7mA, dual 14mA
  • Frequency response: 20Hz - 20kHz (-0.2dB)
  • Types DIP 8 plated Gold 8 pins
  • Weight: 10gr x2
  • Dimensions: 29x12.4x14.5mm (excluding socket)
Compatibility for models:
Dual Op-amps type 5532:
AD823, AD823AN, AD8066, AD823AN, AD823, AD823AN, AD812A, AD827C, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832.
Single Op-amps type 5534:
NE5534, LT1122, TL071, OPA134, OPA627, AD811, AD829, AD844, OPA604, AD8610, AD711, AD797, LME49990, LME49710.
Colissimo - TNT - SoColissimo
