BURSON AUDIO SUPREME SOUND SS OPAMP V6 VIVID Single Discrete OPA (Pair)
BURSON AUDIO Supreme Sound SS OPAMP V6 - VIVID Discrete single OPA (Unit)
Reference : 12178
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Burson Audio Vivid Single Pair x2
Burson Audio Vivid Single Pair x2 AOP à Transistors Discret Mono (La paire)
High resolution, dynamic, balance
The AOP Burson V6 ViVid and Classics are evolutions of the V5 series with a particularly successful straight sound balance. They will bring openness, timbre, dynamics and sound image in three dimensions to any Hifi equipment compatible with DIP8 support compatible NE5534 single or NE5532 dual according to the versions.
A further improvement in design
The Burson V6 discrete AOPs are now as stable on the unity gain stage buffers as they are on the current voltage I/V stages of the DAC stages. The Burson v6 is now equipped with 0.5% metal film resistors and two hand-sorted FET stages. The VIVID version brings more definition, the classic version brings more timbre.
Reverse protection system
A new protection system allows for greater reliability of these discrete, high performance AOPs. The Burson AOP V6 is designed to survive any upside down DIP 8 mounting accident.
Compatibility list
Dual OPA Type 5532 :
AD823, AD823AN, AD8066, AD8620, AD712, AD827, C4570, JRC4556AD, JRC4580, JRC5532, JRC5532D, JRC5534, LF353, LM4562, LME49860, LM833N, MUSES8920, NE5532, NEC4520, NEC4570, NJM2068D, NJM2114, NJM2214D, NJM4558, NJM4558D, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832.
Single OPA Type 5534 :
NE5534, LT1122, TL071, OPA134, OPA627, AD811, AD829, AD844, OPA604, AD8610, AD711, AD797, LME49990, LME49710.
Product typeOPA
Min required voltage+/-3.5V / 7VDC
Max voltage+/-16.5V / 33VDC
ConsumptionSingle : 7mA
Dual : 14mA
Frequency response20Hz - 20kHz (-0.2dB)
Contacts typeDIP8, Gold plated
Weight2x 10g
Dimensions29 x 12.4 x 14.5mm (without socket)
Burson Audio Vivid Single Pair x2 AOP à Transistors Discret Mono (La paire) Burson Audio Vivid Single Pair x2 AOP à Transistors Discret Mono (La paire)
OPA TypeSingle
3 reviews
Great! Worth it!
Got a Burson Playmate 2 with a Hifiman Arya Stealth.
The Upgrade from a ZXR to the Burson was already a HUGE step. Had at this time only the Beyerdynamics DT 700 Pro X.
Back to Topic!
For my AMP/Setup it makes the sound warmer, smoother!
Soundstage was gettiing bigger with switching the Duals on I/V stage and to put the singles (LP stage) in addtionally it feels like i am getting a bit smaller soundstage, but still got more warmness/smoothness!
These are worth purchasing!
salutations d'Allemagne
This review has been posted for BURSON AUDIO SUPREME SOUND SS OPAMP V6 VIVID Single Discrete OPA (Pair)
Excellent
Ces AOP Vivid simples ont remplacé avantageusement des AOP OPA627 et OPA828 (AOP très réputés) sur mon Streamer DAC Cocktail X45 Pro.
Meilleure aération, meilleure tenue du grave, scène sonore plus tridimensionnelle. Bref. Satisfait de l'achat!
Verry good opamps
Replaced the default JRC 5534 's in burson playmate 2.
Very good transparency.
Vivid's reveal rough edges in the audio setup so if you can't stand to listen with them then you have some more work to do on your setup.
