OPA1622 Stereo AOP on DIP 8 socket (unit)
BURR BROWN OPA627 Double AOP on stand New
This OPA1622 is ideal for the replacement of any OP NE5532, OPA2134 DIP8 compatible amplifier, An excellent stereo AOP, dynamic, straight, affordable, which will find its place notably in the output of DAC and headphone amplifier.
Strengths:
  • High rejection rate
  • JRC/NE 5532 compatible DIP 8 support and derivatives
  • Total harmonic distortion: -119dB
12489
10,90 €tax incl.
9,08 € tax excl.
Accessories
-TI OPA1622 AOP STEREO DIP8 support-
This Texas Instrument PDO prefigures the latest generation of the U. S. manufacturer's dedicated High Fidelity AOP. With a high performance noise rejection and feed noise filtration rate, this PDO has outstanding dynamics and a total harmonic distortion of -119dB theoretical for a current of 145mA.
Featuring a wide operating range of voltage supply voltage (2V to 18V) with a current requirement of only 5.1 mA it will replace a large number of DIP 8 compatible NE5532 type DOPs and derivatives : OPA2134, LM4562.
Technical data:
  • Slew rate: 10V/µs
  • Load capacity: 600pF
  • Open loop gain: 136 dB (at 600 Ohm load)
  • Output power: 100mw at 32 Ohm load capacity
  • Operating voltage range : From 2 to 18V (+/- supply voltage)
  • Linear current capacity: 80 mA (+145mA / - 130mA)
  • Bandwidth: 32Mhz
  • Bipolar input type input
  • PSRR rejection rate: 120 dB at 20 kHz
Sold per unit
Datasheet PDF OPA 1622
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
très bien
En remplacement de l'OPA d'origine du little dot1+ je note une nette amélioration à moindres frais, la scène sonore c'est élargie, plus de lisibilité en général. Très satisfait de Audiophonics également
This review has been posted for OPA1622 Stereo AOP on DIP 8 socket (unit)
This OPA1622 is ideal for the replacement of any OP NE5532, OPA2134 DIP8 compatible amplifier, An excellent stereo AOP, dynamic, straight,...
