ACCUSILICON AS318-B-983040 Ultra Low Jitter Clock 98.3040MHz
This extremely low phase noise crystal oscillator (< 90dBc @ 10Hz) is intended for professional recording equipment as well as audiophile electronics precision devices.
Reference : 13730
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Accusilicon precision crystal oscillator clock
Accusilicon Crystal Oscillator AS318-B-983040
 The AS318-B-100 provides a very low jitter - measured 0.198ps on the 10Hz-1MHz band and 0.075ps on the 12-80MHz band.
Valued for their low power consumption (< 25mA @ 15pF) the Accusilicon clocks also have a high resistance to thermal stresses (operational from -20 to 85 ° C).
This component integration is nice and easy. It is powered by 3.3V (within +/- 0.3V) and give excellent results with a 0.1uF capacitor filtered power supply.
These electronic clocks now equip the Audio-GD devices and provide additional accuracy over TCXO clocks. They are to be found in R2R models with 90M clocks as well (not compatible with R2R11).
DIP-crystal clock 14 accusilicon
TypeCrystal Oscillator
Frequency98.304MHz
WaveformCMOS
Output LevelState "0": 10% Vdd
State "1": 90% Vdd
Rise / Fall4ns @ 20-80% Vdd
Jitter198fS(0.198pS) @ 10Hz - 1MHz
75fS(0.075pS) @ 12kHz - 80MHz
Frequency tolerance-20 / 20 ppm
Max Load15pF
Duty Cycle45-55%
Supply (VDD)3.3V (+/- 0.3V)
DimensionsWidth: 20.83mm
Length: 13.21mm
Height: 5.08mm + 6.35mm (legs)
pinout
PIN 1oE
PIN 7GND
PIN 8OUT
PIN 14Vcc
2 reviews
Satisfait
J'ai acheté cette horloge pour remplacer celle de mon audio gd nfb29. J'espérais une amélioration et je suis satisfait. Je ne 'ai plus de dureté, d'aigus trop présent, le son c'est adoucit.
Je ne suis pas un technicien mais j'y suis arrivé facilement. Mes soudures sont moches mais ça marche.
This review has been posted for ACCUSILICON AS318-B-983040 Ultra Low Jitter Clock 98.3040MHz
masterclock audio-gd nos7
Ajoutée en masterclock pour passer d'un master 7 à un nos7 audio-gd le résultat est impressionnant !
C'est plus qu'une amélioration de la qualité sonore, c'est un autre dac !
L'écoute est d'emblée dénuée de la moindre agressivité, richesse des détails et musicalité ne se contredisent pas, les basses, les voix, les timbres, la finesse des cymbales, ect... sont un régal ;-)
Et alimentée indépendamment en interne comme le module usb Amanero par des module LT3045 c'est encore mieux.
Et après une dizaine de jours d'écoute quotidienne de plusieurs heures, j'ai bien l'impression que c'est encore un peu mieux sur les basses (rodage ?).
Bref, un rapport qualité/prix imbattable, Kingwa d'audio-gd (très réactif) explique toujours la marche à suivre, merci à lui.
Ecoute sur 2 pc audios Roon, audio-gd Nos7entrée Amanero,Master9 et blocs 2H panneaux Magnepan 3.7
This extremely low phase noise crystal oscillator (&lt; 90dBc @ 10Hz) is intended for professional recording equipment as well as audiophile...
