ELNA SILMIC II RFS Aluminium Audio Capacitor 35V 1000µF
Elna Silmic II Audio Capacitor RFS aluminium 50V 1000uF
Reference : 13353
3,50 €tax incl.
2,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audio capacitor aluminum RFS series
These high-performance capacitors use silk fibers instead of traditional paper as terminals insulation.
The flexibility of the silk fiber is an ideal material for use in the field of precision audio. It reduces the stiffness of the peaks in the medium and high frequencies while enhancing massive and clear low frequencies.
The legs are in OFC copper for extremely low distortion.
Attention this is an electrolytic capacitor, so polarized: the positive pole is indicated by the longer leg.
TypeAluminum electrolytic capacitor
Capacitance1000μf
VCC35 VDC
Tolerance20%
Temperature-40 + 85 ° C
Diameter (body):18mm
Length (body)35.5mm
Connectors spacing7.5mm
Connector diameter0.6mm
Connector materialsOFC
PolarizedYes
Connector lengthPositive: 20mm
Negative: 15mm
Tolerance (%)20.0
Capacitor capacitance1000
Rated voltage (V)35.0
Capacitor typeElectrolytic capacitor
Capacitor formatRadial
