Capacitor 40V 22000µF
These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of tinned Copper with a diameter of 1.2mm allow compatibility with most "Snap In" capacitors.
Product type | Capacitor |
Capacity | 22000µF |
Voltage | 40VDC |
Tolerance | ±20 |
Rated Ripple Current IR @ TMax, 100Hz | 4.4A |
Surge voltage | 46VDC |
ESR @ 100Hz | 18mΩ |
ESL | 20nH |
Maximal reverse voltage | 2V |
Loss factor (tan ∂ @ 100Hz) | 25 |
Nominal current IR for 5min | 5280µA |
Useful lifetime | 3000h @ +125°C 8000h @ +105°C 16000h @ +85°C |
Temperature range | -40°C to 125°C |
RoHS |
Général | |
Dimensions | Ø35 x 50mm |
Diamètre fils | 1.2mm |
Longueur des fils | 9mm |
Espacement des fils | 10mm |
Tolerance (%) | 20.0 |
Capacitor capacitance | 22000 |
Rated voltage (V) | 40.0 |
Capacitor type | Electrolytic capacitor |
Capacitor format | new |
