MUNDORF MCAP EVO Capacitor 450V 1μF
Reference : 6873
10,50 €tax incl.
8,75 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Condensateur Mundorf Mcap EVO
Mundorf Mcap EVO
Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance1,00 µF
Voltage450V
Tolerance±3%
Diameter25
Lengthr16
Connct wire diameter0,8
Connect wire length (A)35
Connect wire length (B)50
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3.0
Capacitor capacitance1
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
Excellents !!
Les condensateurs Mundorf méritent leur réputation.
Ces deux-là ont remplacé deux condensateurs 1uF MKT de sortie de mon préampli phono, amélioration immédiate.
Commandés un jour et reçus le lendemain, on ne peut pas être plus rapide, bravo Audiophonics !!
This review has been posted for MUNDORF MCAP EVO Capacitor 450V 1μF
Excellente qualité
Utilisé en remplacement des condensateurs MDL de vieilles Jamo de 16 ans. Résultat plutôt convaincant.
De plus, service Audiophonics de très bon niveau.
Très satisfait de mon achat!
MCAP EVO 1µF
Condensateur de bonne qualité.
Utilisé en bypass (// à un condensateur chimique)
La nouvelle géométrie EVO (capa moins long, mais de plus gros diamètre) permet une fixation aisé sur pcb.
Aucun problème
Produit recommandé
Excellent
J'ai remplacé tous les condensateurs des filtres de mes enceintes Klipsch CW3 par cette série de condensateurs pour un excellent résultat.
Je recommande cette série de condensateurs.
Qualité !!!
