Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Type | Capacitor Mcap EVO |
Capacitance | 0,010 µF |
Voltage | 650V |
Tolerance | ±5% |
Diameter | 12mm |
Lengthr | 12mm |
Connect wire diameter | 0,6mm |
Connect wire length (A) | 35mm |
Connect wire length (B) | 35mm |
Maximum room temp | 85°C |
Dielectric | Polypropylene (PP) |
Metallisation | Aluminum |
Dielectric loss | 0.0002@1kHz · 0.0001@10kHz |
Tolerance (%) | 5.0 |
Capacitor capacitance | 0.01 |
Rated voltage (V) | 650.0 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
