MUNDORF MCAP EVO OIL Capacitor 450V 22μF
Reference : 7302
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Condensateur MUNDORF MCAP EVO OIL Condensateur 450V 22µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance22 µF
Voltage450V
Tolerance±3%
Diameter50
Lengthr35
Connct wire diameter1,0
Connect wire length (A)35
Connect wire length (B)75
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3.0
Capacitor capacitance22
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Bon condensateur à utiliser à bon escient
J'utilise ce condensateur pour les filtres d'enceinte, mais pas pour le passage direct du signal vers les HP, pour les retours à la masse ou les compensations d'impédance du HP. Ca forme particulière, gros diamètre et longueur faible, permet de faire des filtres qui tiennent sur des plaques de plus petites surfaces.
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 450V 22μF
