MUNDORF MCAP EVO OIL Capacitor 450V 3.9μF
4.0 / 5
Reference : 7295
7,08 €tax excl.
Available
Shipping date: 16-09-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Condensateur MUNDORF MCAP EVO OIL Condensateur 450V 3.9µF
Mundorf MCAP EVO Oil
The EVO series at Mundorf is intended to offer very high audio precision at a low price and with minimal space-use
Its polypropylene film (PP) is metallized with a layer of aluminum as thick as possible and with a proprietary geometry (Evolution Winding). The coil is then hand-mounted in a shell designed to reduce vibrations.
All these features contribute to a very lively audio reproduction that deeply respects microdynamics and stereophony. The whole EVO series is compliant to the highest standards of safety (self-healing).
Rigid wires for connections are long enough to allow vertical or horizontal mounting. Note that the shorter tab indicates the outer sheet of the capacitor.
This model belongs to the EVO Oil range introducing an oil impregnation step of the polypropylene (PP) films before building the coil. This maneuver removes residual air bubbles with formidable efficiency, which drastically reduces the electrical and mechanical losses associated with vibrations.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance3,90 µF
Voltage450V
Tolerance±3%
Diameter25
Lengthr27
Connct wire diameter0,8
Connect wire length (A)35
Connect wire length (B)50
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Capacitor capacitance3.9
Colissimo - TNT - SoColissimo
Maxime D.
I just compared Mundorf EVO Aluminium Oil 3.9uf 450V with my currently installed Audyn Q4 3.9uf 400V in tweeter section. Mundorf disappointed me. Yes, it is audible that Mundorf has significantly lower distortion in comparison to Q4, but Mundorf sounds monotonously and overly smooth, even were it is not needed. Mundorf has a poor macrodynamics in comparison to Q4, but good microdynamics. I've listened Adele - Take It All and Lenny Kravitz - Rock And Roll Is Dead, and both tracks no movement of sound sources, it sounds like a big pile of good quality sound, but not as exciting performance.
This review has been posted for MUNDORF MCAP EVO OIL Capacitor 450V 3.9μF
