The MCAP RXF (Radial Xtra Flat) are a type of capacitor featuring an optimized geometry with compact housing. They cater to builders ambitious HiFi.
The internal winding diameter and the internal and external contact surfaces have been increased to the maximum to reduce electric losses. This gives a very low internal resistance and residual inductance.
The MCap RXF is ideal for detailed and dynamic music reproduction.
Type | Polypropylene Aluminum Capacitor |
Capacitance | 4.7µf |
Max voltage | 600VDC |
Maximum tolerance | 3% / 1.5% Typical |
Loss factor | tan = 0.0002@1kHz@1µF |
Dimensions | 35 x 33 x 27mm |
Spacing | 15.24 x 20.7mm |
Tolerance (%) | 1.5 |
Capacitor capacitance | 4.7 |
Rated voltage (V) | 600.0 |
Capacitor type | Film capacitor |
Capacitor format | Radial |
