capacitorsMundorf MCAP RXF
Mundorf innovates by introducing a new type of capacitor, the Mcap RXF (Radial Xtra Flat). Their optimized geometry as well as their compact housing should attract audio professionals as well as ambitious Hi fi enthusiasts.
Its internal winding diameter as well as the internal and external contact surfaces have been increased to the maximum to reduce losses. This gives an internal resistance as well as a very low residual inductance.
The MCap RXF will convince you with an extremely detailed and dynamic music reproduction.
Technical specifications:
Dieletric: Polypropylene
Maximum voltage: 350-600-800VDC
Tolerance: Maximum: 3% Typical: 1.5%
Loss factor: tan =0.0002 @ 1kHz 1μF @
MKP-capacitors | RXF | |
Capacity | VDC | casing |
350V | ||
350 | 4 | |
22.00 | 350 | 4 |
600V | ||
0.47 | 600 | 1 |
0.68 | 600 | 1 |
0.82 | 600 | 1 |
1.00 | 600 | 1 |
1.20 | 600 | 2 |
1.50 | 600 | 2 |
1.80 | 600 | 2 |
2.20 | 600 | 2 |
2.70 | 600 | 3 |
3.30 | 600 | 3 |
3.90 | 600 | 3 |
4.70 | 600 | 3 |
5.60 | 600 | 3 |
6.80 | 600 | 4 |
8.20 | 600 | 4 |
10.00 | 600 | 4 |
800V | ||
0.10 | 800 | 1 |
0.22 | 800 | 1 |
0.33 | 800 | 1 |
casing | B [mm] | H[Mm] | T [mm] | d [mm] | RM [mm] |
1 | 29 | 29 | 17 | 11.7 | 15.24 |
2 | 29 | 29 | 22 | 16.7 | 15.24 |
3 | 35 | 33 | 27 | 20.7 | 15.24 |
4 | 49 | 49 | 27 | 20.7 | 15.24 |
