MUNDORF MCAP SUPREME Capacitor 600V 2.2μF
Reference : 1004
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
The Mcap Supreme is an internationally recognized ultimate capacitor.Its remarkable sound qualities are obtained through a combination of advanced techniques:- A winding technology without inductance : Two coils are interlaced in the capacitor, so that the inductors are eliminated reciprocally. These two coils are connected in series. This means that for the production of a 1μF Mcap Supreme capacitor, two 2μF coils are used, which would give 4μF for a conventional capacitor.
- Use of the best materials : the polypropylene sheet used for Mcap Supreme is characterized by a minimal loss.
- Robust plastic and aluminum housings : This prevents micro feedback and retains important signal details
The results of listening justify all the effort that we put in the MCap SUPREME.
No capacitor gives as much spacialization and perfect reproduction of the finest musical nuances. You can use MCap SUPREME in any audio application that requires high-precision filtering, the result
will always be surprising and convincing. Expect a new dimension of musical reproduction. This effect is also remarkable with modest speakers!
For a great audiophile experience, try this capacitor!
DielectricPolypropylene
Tolerance±2%
Dielectric lossTan = 0.00002 à 1kHz & 0.00001 at 10kHz
Capacity2,2µF
Voltage600VDC
Body Diameter25 mm
Body Length52mm
Wiring Diameter1,0 mm
Wiring length60mm
Tolerance (%)2.0
Capacitor capacitance2.2
Rated voltage (V)600.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Etonnant!
Mises en lieu et place des condensateurs Hovland Musicap de sortie d'un préampli Hovland HP100i.
Cette substitution se traduit par plus de matière, plus d'image et surtout beaucoup plus de naturel et d'aisance. L'écoute pendant des heures ne génère plus aucune fatigue et permet de (re)découvrir sa discothèque.
A recommander chaudement.
This review has been posted for MUNDORF MCAP SUPREME Capacitor 600V 2.2μF
Excellent
Utilisé en couplage dans un bloc de puissance adcom GFA 5300 et en remplacement du condo MKT original....une amélioration incroyable... beaucoup plus de profondeur et de transparence... une belle fluidité et un gain en extrême grave et extrême aigu... quelle différence !!
Un rodage semble toutefois nécessaire pour arrondir un peu.
