WIMA FKP-2 Polypropylene Capacitor 5mm 1000V 100pF
Condensateur Polyester Wima FKP-2 5mm.. 100pF
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
Reference : 6049
0,60 €tax incl.
0,50 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
WIMA FKP-2
Polypropylene Capacitor 5mm 100V 100pF
WIMA FKP-2 Condensateur Polyester
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications. Moreover, they have an extended service life, even at high temperatures.
Product typeCapacitor
Capacity100pF
Voltage100V
63VAC
Tolerance2.5%
DielectricPolypropylene foil (PP)
ElectrodesMetal foil
Temperature range-55°C to +100°C
Insulation resistance (@+20°C)≥ 5x105MΩ
Dielectric absorption0.05%
Operational life> 300000h
Dissipation factor (@ +20°C)≤ 3x10-4 @ 1kHz
≤ 3x10-4 @ 10kHz
≤ 4x10-4 @ 100kHz
≤ 10x10-4 @ 1MHz
RoHS
Dimensions4.5 x 6 x 7.2mm
Contacts spacing5mm
Tolerance (%)2.5
Capacitor capacitance0.0001
Rated voltage (V)1000.0
Capacitor typeFilm capacitor
Capacitor formatRadial
LAMA06
CA5ACTERISTIQUES AUDIO EXCELLENTES.UTILISE POUR MODIFIER LA CHARGE CAPACITIVE DE PREAMPLI RIAA EN FONCTION DES CELLULES PHONO UTILISEES
This review has been posted for WIMA FKP-2 Polypropylene Capacitor 5mm 1000V 100pF
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low...
