WIMA FKP-2 Polypropylene Capacitor 5mm 1000V 1.5nF
Condensateur Polyester Wima FKP-2 5mm 1.5nF
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
Reference : 6043
0,45 €tax incl.
0,38 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
WIMA FKP-2
WIMA FKP-2 Condensateur Polyester
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications. Moreover, they have an extended service life, even at high temperatures.
Product typeCapacitor
Capacity1.5nF
Voltage1000VDC
250VAC
Tolerance2.5%
DielectricPolypropylene foil (PP)
ElectrodesMetal foil
Temperature range-55°C to +100°C
Insulation resistance (@+20°C)≥ 5x105MΩ
Dielectric absorption0.05%
Operational life> 300000h
Dissipation factor (@ +20°C)≤ 4x10-4 @ 1kHz
≤ 4x10-4 @ 10kHz
≤ 5x10-4 @ 100kHz
RoHS
Dimensions7.2 x 8.5 x 7.2mm
Contacts spacing5mm
Tolerance (%)2.5
Capacitor capacitance0.0015
Rated voltage (V)1000.0
Capacitor typeFilm capacitor
Capacitor formatRadial
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low...
