WIIM AMP ULTRA Connected Amplifier Gray
New
The WiiM Amp Ultra is the culmination of a new generation of connected amplifiers, designed to meet the highest expectations of modern audiophiles and audio technology enthusiasts. With its meticulous design, remarkable power and network intelligence, this all-in-one device brilliantly combines high-performance amplifier, audiophile streamer and high-end digital-to-analog converter. Able to drive a wide variety of passive speakers with ease, it transforms your audio installation into an immersive, fluid, connected and upgradeable multiroom hi-fi system.
By buying this product you get 59 loyalty points
Reference : 20961
599,00 €tax incl.
499,17 € tax excl.
WiiM Amp Ultra Connected Amplifier Streamer ES9039Q2M WiFi 6 Bluetooth 5.3 2x200W 4 Ohm Gray
WiiM Amp Ultra: Front view
The WiiM Amp Ultra is the culmination of a new generation of connected amplifiers, designed to meet the highest expectations of modern audiophiles and audio technology enthusiasts. With its meticulous design, remarkable power and network intelligence, this all-in-one device brilliantly combines high-performance amplifier, audiophile streamer and high-end digital-to-analog converter. Able to drive a wide variety of passive speakers with ease, it transforms your audio installation into an immersive, fluid, connected and upgradeable multiroom hi-fi system. Whether you're listening to high-resolution music, watching a movie or simply enjoying a sound experience perfectly calibrated to your space, the WiiM Amp Ultra is the technological and acoustic heart of your home audio environment.
WiiM Amp Ultra: Key features
WiiM Amp Ultra: Sophisticated, ergonomic design
The WiiM Amp Ultra's sleek, one-piece aluminum chassis is enhanced by a 3.5" color glass touchscreen. This interactive interface makes it easy to navigate between your sources, manage playlists and control playback, directly from the device or the WiiM Home mobile application.
WiiM Amp Ultra: Design
WiiM Amp Ultra: A sublime sound experience
Beyond its elegant design, the WiiM Amp Ultra contains cutting-edge audio technology. It's equipped with a robust Class D amplifier using two TI TPA3255 chips and TI OPA1612 PDUs, enabling it to deliver up to 2x 200W into 4Ω to drive a wide range of loudspeakers, from bookshelves to columns.
Sound quality is assured by a top-quality DAC, the ESS ES9039Q2M chip, capable of decoding high-resolution audio files up to 24-bit 192kHz. The result is crystal-clear sound reproduction, with deep, controlled bass, rich mids and detailed highs, offering a wide, immersive soundstage that brings your music to life.
WiiM Amp Ultra: DAC and amplifier chip
WiiM Amp Ultra: Post-Filter Feedback technology
To deliver outstanding sound quality, the WiiM Ultra Amp also features advanced Post-Filter Feedback (PFFB) technology, designed to dramatically reduce distortion, improve clarity and ensure consistent sound quality, regardless of speaker load. This PFFB technology dynamically compensates for these inconsistencies, promoting precise, balanced and natural sound reproduction. The result is a wide soundstage, incredible richness of detail and an extremely immersive musical experience.
WiiM Amp Ultra: PFFB logo
WiiM Amp Ultra: Advanced thermal management
The WiiM Amp Ultra benefits from a particularly efficient thermal management system, allowing the heat generated by the amplification to be dissipated. It uses copper heat pipes to transfer heat from the heating components. This heat is then routed to a large aluminum heatsink for efficient heat dissipation. All this is complemented by precision PID control, enabling real-time temperature regulation for optimum cooling and enhanced reliability.
WiiM Amp: Thermal management
WiiM Amp Ultra: Next-generation wireless streaming
To help you enjoy all your music in the best possible conditions, the WiiM Amp Ultra is equipped with the latest wireless technologies. It features WiFi 6 tri-band and Bluetooth 5.3 connectivity, with support for SBC and AAC codecs. So you can enjoy your music simply and in high quality.
WiiM Amp Ultra: All your music in one place
With the WiiM Amp Ultra, you benefit from extensive compatibility with the most popular streaming services. So you can stream your music directly from Spotify, Amazon Music, TIDAL, Qobuz, Deezer, Pandora, iHeartRadio, TuneIn, Soundcloud and many more. What's more, if you prefer to use your own apps rather than WiiM integration, the Amp Ultra is also compatible with Chromecast, Alexa Cast, Spotify Connect, TIDAL Connect, Qobuz Connect, DLNA, SqueezeLite and Roon (certification pending).
WiiM Amp Ultra: Logos for streaming services and protocols
WiiM Amp Ultra: An ergonomic design interface
The front panel of the WiiM Amp Ultra features a superb 3.5" glass touchscreen. This is combined with an ergonomic interface, capable of displaying album covers, meters and access to all the device's settings and navigation.
WiiM Amp Ultra: Screen and interface
WiiM Amp Ultra: RoomFit™ acoustic correction
Thanks to its integrated RoomFit technology, the WiiM Amp Ultra is able to take acoustic measurements of your room, so you can adjust the sound reproduction of your system according to your listening environment and equipment.
WiiM Amp Ultra: RoomFit acoustic correction
WiiM Amp Ultra: Customize your sound
Thanks to an advanced equalization system and a wide range of profiles, you can tailor your system's output to your personal taste. The WiiM Amp Ultra features 24 predefined EQ profiles, a 10-band graphic and parametric equalizer, independent EQ settings for each input, and subwoofer cutoff frequency control.
WiiM Amp Ultra: equalizer
WiiM Amp Ultra: Extensive connectivity
The WiiM Amp Ultra boasts particularly versatile connectivity, and will integrate easily with turntables, CD players and TV sets. What's more, it can stream to any WiiM or Bluetooth-compatible device.
WiiM Amp Ultra: Connection diagram
WiiM Amp Ultra: Take control with the WiiM Home application...
The WiiM Home mobile app lets you take full control of your WiiM Amp Ultra: play music, adjust equalization, manage your multiroom setup, set alarms or update firmware, all simply from a smartphone or tablet.
WiiM Amp Ultra: WiiM Home application
WiiM Amp Ultra: ...or with the WiiM Voice Remote 2 remote control
The WiiM Voice Remote 2 also lets you control all WiiM Amp Ultra functions. It features a robust aluminum chassis, rechargeable battery and voice commands. What's more, some of these buttons can be configured to suit your needs.
WiiM Amp Ultra: WiiM Voice Remote 2
Product typeConnected amplifier
Inputs1x Stereo RCA
1x Optical Toslink
1x HDMI ARC (Dolby Digital 5.1 formats support)
OutputsSpeaker binding post
1x USB-A (support up to 8 channels, UAC 2.0 compatible)
1x Subwoofer output (mono RCA)
Network connectivityBluetooth 5.3 (supports bi-directional A2DP, AVRCP, HID and works with the WiiM voice-controlled remote control)
WiFi 6 (upgradeable to WiFi 6E)
Ethernet RJ45 (100Mbps)
DAC chipESS ES9038Q2M
Amplification chips2x TI TPAA3255
OPA TI OPA1612
Output power (THD 0.08%)2x 100W @ 8Ω
2x 200W @ 4Ω
Amplification technologyClass D with PFFB (Post-Filter Feedback) technology
THD+N≤ 0.005%, -106dB (A-wt)
SNR≥ 120dB
Dynamic range≥ 120dB
Damping factor94
Frequency response20Hz - 20kHz ±0.5dB
Impedance range2-8Ω
Supported sampling ratesPCM up to 24bit 192kHz
Equalizer (EQ)24 equalization profiles
Integrated acoustic correction with microphone
Supported streaming protocolsWiiM Home app
Chromecast audio
Spotify Connect
TIDAL Connect
DLNA, LMS
Roon Ready (certification in progress)
Multiroom audioCompatible with WiiM Home, Google Home and Alexa
Touchscreen dimensions3.5"
ColorGray
Dimensions (L x P x H)200 x 211 x 76.2mm
Weight2.45kg
Package1x WiiM Amp Ultra
1x Power cable
1x RCA cable
1x Optical cable
1x HDMI cable
1x WiiM Remote 2 remote control
4x Banana plugs
InputRJ45
InputHDMI ARC
InputWiFi
OutputWiFi
OutputSpeaker terminal
OutputBluetooth
OutputUSB
OutputSubwoofer
DAC / ADC ChipES9039Q2M
Max sampling rate192kHz
ColorGray
Remote ControlYes
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsChromecast
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
WIIM AMP ULTRA Connected Amplifier Streamer ES9039Q2M WiFi 6 Bluetooth 5.3 2x200W 4 Ohm Gray
The WiiM Amp Ultra is the culmination of a new generation of connected amplifiers, designed to meet the highest expectations of modern audiophiles...
