1877PHONO TAD-88 SV Connector DIN Female 5 pin Gold plated 24K PTFE Silver
1877PHONO TAD-88 Connector DIN Female 5 pin Gold plated 24K PTFE Silver
Reference : 11071
35,90 €tax incl.
29,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This 5 pin DIN connector has been specially designed for analog applications and is intended to dramatically improve the input signal of your deck.
The choice of conductive materials as well as insulation has been done scrupulously and the finishes are exemplary. This connector is placed directly in the category of high-end connectors, thanks to its gold plated Copper pins, as well as its PTFE insulation.
It accepts cables with a maximum diameter of 8.6mm, screw tightening.
Characteristics :
  • Gender: Female
  • DIN 5-pin copper
  • Screw cable
  • Contacts: Gold plated 24K
  • Max Cable Diameter: 8.6mm
  • Silver color
  • Weight: 16g
  • Overall length: 42mm
  • Overall Diameter: 11.8mm
  • Sold individually
Max cable diameter (mm)8.6
Mounting typeTo screw
ConnecticFemale
Contacts number5
Max panel thickness (mm)N/A
ConnectorDIN
