Really high quality spade. The construction with the 2 half’s of the spade work like a spring and help clamp in the binding post much better than a solid spade.
Tellurium copper spade 24K gold-plated gold plated Ø5mm
The Pangea Audio Xtreme forks will give your speaker cables excellent performance. These are designed so that you can either solder them to your speaker cables or attach them with the screws on the body.
To ensure a high resistance failbe and operation with high currents, these connectors are machined from Tellurium Copper and then receive a 24k gold plating for high resistance to oxidation.
In addition, these forks feature an innovative and patented spring compression system to secure the fork attachment.
Compatibility | 1/4" or 5/16" Connectors |
Max cable diameter | Ø5mm |
Low electric resistance | - |
High current | - |
Fixing | Soldering or screwing |
Material | Tellurium copper |
Plating | Gold 24k |
Spring compression locking grip | - |
Max cable diameter (mm) | 5.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Spade |
Contacts Material (Connector) | Tellurium Copper |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Matt H.
Aristotel Eduard G.
Gerben M.
Jean-Pierre L.
Grzegorz B.
