Viablue T6s Gold plated 24K Spade Ø9.5mm (Set x4)
Viablue T6s Fourches (set x4) Ø 9.5mm
4.5 / 5
Reference : 3140
89,99 €tax incl.
74,99 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
Viablue T6s Forks Gold plated 24K Ø 9.5mm (Set x4)
Top-class connectors.
Minimum resistance. Maximum quality.
The ViaBlue T6s fork connectors are 24 karat gold plated, and the body is made of aluminum.
  • 6 and 8mm fork (2 positions on the fork)
The ends of the T6s connectors are detachable so that they can be interchanged.
All bodies for the ViaBlue ™ T6s series connectors are identical (except XLR connectors).
Only the contact parts change
Tips available separately
Flexible application. For all cable diameters.
All connectors of the T6s series are supplied with 2 diameter reducers
These reducers allow the connectors ofx adapt to cable diameter.
The small reducer has an outer diameter of 7.5 mm and an internal diameter of 4.5 mm.
Thus cables with a diameter of 3 mm to 4.5 mm can be mounted securely.
The large one with an outer diameter of 9.5 mm and an inside diameter of 7.5 mm.
Thus cables with a diameter of 5 mm to 7.5 mm can be mounted securely.
Without reducers of cables with a diameter of 7.5 mm to 9.5 mm can be installed.
  • The ends of the cables are to be welded to the contact.
  • Interchangeable with all other Viablue T6s connectors
  • Plated 24k gold
  • They accept cables up to 9.5 mm in diameter
  • Diameters for different cable sizes from 3mm to 9.5mm
Precision screwdriver available in the accessories below./ P>
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
ConnectorSpade
2 reviews
Belles fiches, un peu de bricolage...
Ces fiches sont superbes, j'ai pu y entrer 2 sections de 4 mm2 de mon Sommercable Elephant mais c'est juste pile poil pour 8 mm2.
Ne croyez pas les installer en 5 minutes, j'ai dû bricoler un peu.
Déjà la clé Allen n'est pas fournie, mon jeu de clés Allen n'a pas une clé aussi petite. J'ai dû utiliser un tournevis miniature de mon jeu de tournevis d'horloger. Jusque_là c'est bon, en enlevant le plus petit manchon le câble de 2x4mm2 rentre.
Petite déception, la vis du haut de la fourche tient le capuchon de la fourche mais pas le câble. C'est la vis du bas qui serre le câble mais directement en l'écrasant. J'ai dû rajouter une petite cale pour que la vis vienne presser la cale sur le câble et ne pas le mâchonner.
Sinon c'est très positif, la qualité de ces fourches est extra.
Ce n'est pas si courant de pouvoir entrer une section de 8mm2 dans une fiche !!
Je crois d'Audiophonics a un contrat de transport avec le super héros Flash, les livraisons se font toujours le surlendemain de ma commande, je n'en reviens pas !!
This review has been posted for Viablue T6s Gold plated 24K Spade Ø9.5mm (Set x4)
Buono
Buona manifattura ed estetica, avrei preferito fissaggio cavo con viti a brugola
Consegna veloce
