Viablue TS Spade 6mm Gold plated 24K Ø6mm (Set x4)
Viablue TS Spade Plug Gold Plated 24K Ø 6mm (Set x4)
Reference : 111
59,99 €tax incl.
49,99 € tax excl.
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
TS ViaBlue forks are screwed to the terminals of the speakers to provide firm and durable contact between the speaker cable and the pole terminals.
There are two different fork sizes, with fork spacing of 6 mm and 8 mm.
The TS ViaBlue series has been developed to provide an ideal connector for each type of connection and type of terminal.
All TS plug connectors are protected against short circuits by means of a transparent insulating sleeve.
To help you choose your TS connectors, you can download a fact sheet that provides 1: 1 scale diagrams after printing.
The speaker cables easily and easily fit into TS ViaBlue plugs.
To do this you will just need a wire stripper to strip the cable as well as a socket wrench 1.5 to secure the cable into the plug.
The speaker cable must be stripped to a length of approximately 8 mm.
It is then inserted firmly inside the plug (Ø 6mm max.).
The cable receptacle shrinks inside the plug so that the air flow is reduced when the cable is properly inserted.
Thus, the strands of the cable are protected against oxidation.
The cable is easily fixed by the two large fixing screws, which gives it a very solid position dyears.
No welding is required.
For a better protection of the sensitive strands of high-quality speaker cables against possible deterioration during fixing or against oxidation,
it is recommended to use OFC ViaBlue cable connectors.
Characteristics:
  • Width / spacing between forks: 6mm
  • Overall width of the fork: 12mm
  • Quantity delivered: 4pcs (2 red / 2 black)
Max cable diameter (mm)6.0
Mounting typeTo screw
ConnecticMale
ConnectorSpade
