WBT-0661Cu Nextgen Forks NextGen Ø7mm (The pair)
WBT-0661Cu Spade Plug Copper Nextgen Ø 7mm (La paire)
Reference : 2237
49,90 €tax incl.
41,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
In 1985, WBT designed the first machined connector in one piece with a progressive clamping device.
Since then, the machining technique has been refined, the eight outer contact lamellae are machined on high precision machines using diamond bits.
This patented design has the value of a symbol on the market.
WBT is today synonymous with perfection in the field of audio connection and its reputation is more to do.
In 2003, NextGen technology was introduced by pushing the conduction quality of WBT connectors even further.
Today, this principle extends to the entire range.
The terminal is connected to the cable by crimping.
The two leather-stamped camps on each lug are equipped with Torx screws, which provides a reliable high strength connection.
These forks are therefore fully insulated in accordance with EN 60065 and IEC65 standards.
It is designed for the use of crimped contacts using two Torx screws and accepts cables up to 10 mm² of cross-section.
Finally it is available in two sizes; 6 mm (WBT-0660) or 8 mm (WBT-0680) and two metals; Pure copper coated with a protective layer of Gold24 carats or silver plated rhodium.
  • Signal conductor in the mass made of fine pure copper
  • Diamecable length: 7mm
  • Internal width of the fork: 6.3 mm
  • External fork width: 13.5 mm
  • Plated 24K Gold
T6 precision screwdriver available in the accessories below./ Div>
The WBT patent uses an absorbent elastomeric material sandwiched within the fork.
It makes it possible to establish an extremely high contact pressure during clamping, accepting a current of 100 A continuously.
Moreover, it absorbs vibrations and thus suppresses the generation of magnetostrictive noises. Finally, it guarantees perfect mechanical strength over time
Max cable diameter (mm)7.0
Mounting typeTo screw
ConnecticMale
