WBT-0681CU 24k Gold Plated OFC Pure Copper Spades Nextgen Ø7mm (Set x4)
WBT-0681Cu Spade Plug Copper Nextgen Ø 7mm (La paire)
These WBT-0681Cu forks made of pure OFC Copper with 24k gold plating provide excellent conductivity and a practical and durable clamping system.
4.0 / 5
Reference : 2238
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
WBT-0681Cu
Fourches Cuivre OFC Pur Plaqué Or 24k Nextgen Ø7mm (Set x4)
WBT-0681Cu Fourches Cuivre OFC Pur Plaqué Or 24k Nextgen Ø7mm (Set x4)
In 1985, WBT designed the first one-piece machined connector with a progressive clamping device. Since then, the machining technique has been refined and the eight blades of the external contact are machined on high-precision machines using diamond drill bits. This patented design has the value of a symbol on the market.
Today, WBT is synonymous with perfection in audio connection and its reputation is well established. In 2003, NextGen technology was introduced, taking the conduction quality of WBT connectors even further. Today, this principle extends to the entire range.
The cable is fixed by means of a double clamping system using two copper Torx screws, ensuring excellent mechanical resistance for a reliable connection. These forks accept cables with a cross-section of up to 10mm² and a diameter of 7mm. These forks are fully insulated, in accordance with EN60065 and IEC65 standards.
The WBT patent uses an absorbent elastomeric material that is clamped inside the fork. It allows an extremely high contact pressure to be established during tightening, so that a continuous current of 100A can be accepted. In addition, it absorbs vibrations and thus eliminates the generation of magnetostriction noise. Finally, it guarantees perfect mechanical resistance over time.
Product typeSpades
Contact materialOFC pure Copper
Contact plating24k Gold
Max cable diameterØ7mm
Max cable section10mm²
External total diameter17mm
Package4x Spades (2x with red ring, 2x with white ring)
1x Torx screwdriver
Max cable diameter (mm)7.0
Mounting typeTo screw
ConnecticMale
ConnectorSpade
excellent
En remplacement des WBT 0660 en laiton taillé dans la masse et très solides j'ai essayé les WBT 0681 Cu elles sont plus légères mais solides la musicalité et un peu au dessus certainement du à l'apport du cuivre le prix me parait toutefois un peu élevé d'où 1 étoile en moins.
This review has been posted for WBT-0681CU 24k Gold Plated OFC Pure Copper Spades Nextgen Ø7mm (Set x4)
