Long Female Jack DC 5.5/2.5mm Plug
Jack DC female inlet 5.5 / 2.5mm Long
3.5 / 5
Reference : 13157
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 24-04-2024.
Shipping from France
Billing in France
Technical support in France
Jack socket for mounting electronic component
Socket DC Jack Female
This base female Jack DC 5.1 / 2.5 mm is useful to install a power inlet in your DIY construction projects.
This is the long version of this inlet model. This longer version is suitable for thicker casings.
Supplied with washer and matching nut, installation is made simple for reliable mounting.
Easy installation
Its connectors are wide enough for a clean and robust welding.
They are suitable both to the PCB mounting in cable and welded installation.
This component can be used for prototyping and to repair / construction as well.
supply diy female jack
5.5 2.5 jack socket screw housing
Characteristics
TypeSocket DC Jack female
Inlet dimensionsExternal: 5.6 mm
Pin: 2.5 mm
Length: 8.5 mm
Overall dimensionsMax external diameter: 10.8
Hole diameter: 7.8 mm
PCB connectors Dimensions5.8 mm x 2.8 mm
Panel Thickness max6 mm
Parts supplied
Jack Inletx1
Boltx1
Ringx1
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
ConnectorJack DC
2 reviews
Un poil trop de jeu
Attention diamètre interne de 5.6 certaine prises mâle se déconnectent trop facilement.
This review has been posted for Long Female Jack DC 5.5/2.5mm Plug
Qualité correcte
Produit de bonne facture, attention à ne pas trop chauffer lors du soudage.
