BACHMANN SLRV09 9-port Schuko White
Sommercable SLRV09 Multiprise 9 ports Schuko
3.0 / 5
1507
74,90 €tax incl.
62,42 € tax excl.
In Stock
Shipping date: 18-10-2017.
SLRV09
"Schuko" safety catch, 9 ports
Flickering screen ...
Planned computer or synth: incidents often triggered by power strips from mega-series productions on the DIY market.
Because often we do not want to believe that there are such differences in quality with regard to power strips. This is not only a matter of giving an esoteric opinion in relation to the acoustic qualities (because a power strip can not correct the defects of a "failed" electrical installation), but above all to observe the safety rules.
Goodoperation of a hi-fi device or a computer depends crucially on a constant and reliable power supply, since already a short pulse variation can cause a composition to lose or damage an apparatus.
TheThe most important criteria are a perfect contact quality, an excellent crimping of the conductors inside the case, a heat-resistant and impact-resistant housing material, and a high reliability circuit breaker.
InCooperation battery with an Italian partner, we have designed a high quality power supply with a reasonable price, ideal for powering computer, studio system components, musical instruments and home appliances.
This product is not approved for outdoor use (cable unwinding systems for high voltage: see "Equipment and accessories").
Wewe offer multi-socket blocks for two uses:
One standard "Floor Version" and the other for 19 "rack mounting (19" rack mount kit included)
Cord Length: 2m
ColorBlanc
Colissimo - TNT - SoColissimo
bonjour,
ce produit semble être un produit d'une très bonne qualité,
seul bémol la visserie pour changer le câble d'origine sont
non dévissable avec les tournevis standard ...
question :9 fiches schuko avec un 3 * 1.5 ?
question : sollicite solution ou outil approprié ?
merci,
This review has been posted for BACHMANN SLRV09 9-port Schuko White
