DIY Aluminum Power Strip 8 Schuko Sockets Black
Multiprise DIY aluminium 8 ports Schuko
This DIY power supply unit with 8 schuko ports and grounding benefits from a very good design quality, ideal for supplying clean power to a HiFi audio system. The feed rails are made of copper alloy with large cross-sections (about 6mm²) ensuring very good conductivity.
4.4 / 5
Reference : 3451
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
DIY Power Strip
Aluminum, 8 Schuko Sockets,  Black
Multriprise DIY Aluminium 8 Ports Schuko Noir
This DIY power supply unit with 8 schuko ports and grounding benefits from a very good design quality, ideal for supplying clean power to a HiFi audio system. The feed rails are made of copper alloy with large cross-sections (about 6mm²) ensuring very good conductivity. All components are integrated in a robust black aluminium housing.
The main feature of this power strip is that it is delivered without a power cable, so you can choose this important element.
This power strip is supplied without power cable, which is to be purchased separately. For many high-end power cables, the cable entry of the power strip will have to be widened, its diameter being 9mm.
Product typeDIY Power Strip
Number of Schuko Sokets8
Ground
Conductors materialCopper Alloy (Brass)
Case materialAluminium + Plastic (power strip ends)
Dimensions (LxlxH)490 x 60 x 45mm
Manufacturing originGermany
Power cableSold separately, to mount
Weight900g
Disassembling the power strip
The method of dismantling the power strip for installing the power cable is as follows:
  1. Remove the 8 Schuko sockets by removing the central screw on each one.
  2. Open the power strip in half by opening the upper and lower part of the strip.
  3. Unscrew the ground nut inside the power strip. This allows the bases to slide.
  4. Once the first base plate is out, you will discover a terminal block activated by the screw on top of the rails.
Number of sockets8
FilteringNo
14 reviews
Très bon produit
Un bel objet de bonne facture. De bons contacts, des prises qui tiennent bien, et la possibilité de le fixer au mur ou sur un support en bois est vraiment un plus.
Par contre les prises n'ont pas d'obturateurs pour le sécurité enfants... donc non conforme à la NFC 15100, donc une étoile en moins.
This review has been posted for DIY Aluminum Power Strip 8 Schuko Sockets Black
bon matos
multiprise de qualité, seul le montage du câble est vraiment peu pratique mais avec un peu de patience, c'est réalisable. sinon la possibilité de pouvoir la visser sur un support bois est un plus. pour le son à voir avec l'usage.
besoin de plus ?
cette barette fait parti des premiers prix de la catégorie , comment la critiqueur ?
mon choix c est porté sur le nombres de prises bien sur , mais aussi par la presence du rail en laiton de forte epaisseur qui relie les schuko et garant d une bonne restitution du courant entre les fiches .
pour la qualité c est du très très bon .
les fiches secteurs mal s emboitent avec resistance dans la barette gage d un bon maintien.
seul hic l assemblage !
je n ai jamais rien vue de si peu pratique .
pour un meilleur contact pensez à étamé le bout de vos câbles c est toujours meilleur et ca tient mieux au serrage .
un tres bon choix .
Excellent
Très bonne qualité, assez facile a connecter une fois que l'on a compris qu'il faut tout sortir. un mode d'emploi un peu plus détaillé ne serait pas du Luxe.
Monté avec un in wall 3x 3.5mm diam total 12 mm, a mon avis c'est la limite haute a ne pas dépasser car cela pourrait devenir difficile.
Excellent produit.
Good quality power strip
Very nice power strip. Running Olflex 110cy 3x2.5mm,10,3mm cable. Just had to drill the hole a bit. Has small "pockets" on each end so you can attach it to a wall using screws. If your'e not familar working with electric appliences buy the ready made with the IEC socket on the end. Some skill needed to work on this one.
This DIY power supply unit with 8 schuko ports and grounding benefits from a very good design quality, ideal for supplying clean power to a HiFi...
