XH 2.54mm Ribbon Cable Female / Female 12 Poles No Casing 15cm (Unit)
Flexible Flat Cable for XHP 12 PIN 15cm
This XH 2.54mm female/female ribbon cable will allow you to make quick connections between two XH 2.54mm female connectors for your DIY projects. This takes advantage of copper conductors to ensure very good signal conductivity.
Reference : 11797
1,20 €tax incl.
1,00 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
XH 2.54mm ribbon Cable
XH 2.54mm Ribbon Cable 12 Pole Female / Female Connector 15cm (Unit)
Câble PH 2.0mm Connecteur Mâle / Mâle 12 Pôles 15cm (Unité)
The 12 cables composing this product are detachable.
Cable TypeRibbon cable XH 2.54mm Female / Female
Length15cm
Number of pole12 pole
Conductor materialCopper 7 x 0.16mm
Quantity1 - Unit
Length (m)0.1
ConnecticFemale
Contacts number12
This XH 2.54mm female/female ribbon cable will allow you to make quick connections between two XH 2.54mm female connectors for your DIY...
