A rempli sa mission avec brio (pas le tube des années 90's hein !). Il se coupe très bien (j'avais une bonne pince aussi...) et n'a pas perdu son revêtement lors du sertissage. Que dire de plus sur un embout...
Viablue OFC cable sleeve offer excellent protection against corrosion and oxydation for your high-end cables tip.
They are crimped directly on the cable end, preventing the cable filaments from breaking due to the screwing. It significantly reduces the probability of having a bad electric contact affecting the audio quality.
The protection are built in OFC Copper (pure 99.99%).
They have an insulating plastic sleeve to help mounting the cable the ideal way.
You will need a crimping tool to mount the tip on the cable.
Spécifications | ||
Materials | OFC copper | |
Dimensions | Tube : 2.8mm diameter x 17.5mm length Sleeve 4.8mm Overall length : 27mm |
Max cable diameter (mm) | 2.8 |
Section (mm²) | 4.00 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
Average votes 4.3 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pierre-Yves C.
Pierre-Yves C.
christophe C.
