JANTZEN AUDIO CROSS-CAP Capacitor 400V 82µF
Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality electrochemical capacitors.
Reference : 11780
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Cross-Cap
Capacitor 400V 82µF
Jantzen Audio Cross-Cap Condensateur 400V 1.5µF
The structure of these MKP capacitors is worthy of high-end constructions consisting of metallized polypropylene (ZnAl) film windings, all flooded with epoxy resin to hold the entire body together. The wires are made of 4N grade tinned copper. The parameters of these capacitors have a tolerance of 5% with respect to the European standard IEC 384-16. These capacitors provide a sound without any particular coloration and offer a great recoil of distortion.
Product typeMKP Capacitor
Capacitor filmMetalized (ZnAl) Polypropylene foil
Dielectric insulationPolypropylene
Capacitor typeHorizontal axial
Voltage rating400VDC / 250VAC
Operating temperature-40°C to +85°C
Capacitance82µF
Max tolerance5%
Loss factor at 1kHz (maximum)C < l uF : 5 * 104
C > l < 20 µF : 105
C > 20 µF : 105
Insulation resistance at 1kHzC < l µF : 5 * 104 MOhm
l < 20 uF : 3 * 104 MOhm
C > 20 uF : 104 MOhm
DimensionsØ54 x 58mm
Tolerance (%)5.0
Capacitor capacitance82
Rated voltage (V)400.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Idéale en parallèle du signal
Pour les personnes qui recherchent un filtre haut de gamme, ces Cross Cap sont très bien pour le capas en parallèle du signal principal. Sur la ligne du signal, on préfèrera des Supérior Z ou + ou des Suprème ou +. Cette 82µF m'a servi pour linéariser un woofer. Belle présentation.
This review has been posted for JANTZEN AUDIO CROSS-CAP Capacitor 400V 82µF
Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe,...
