PCM5122 DAC Board for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC2 Pro is a high resolution digital to analog and analog to digital converter, dedicated to be used in combination with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero). It is a sound card for Raspberry Pi optimized to enjoy high quality audio playback at a low price.
It is based on a Burr Brown conversion chip supporting sampling rates up to 24bit 192kHz PCM. It also embeds a low jitter clock circuit and integrates a headphone amplifier.
The input is on a 40 pin GPIO header and the output is on stereo RCA (line) or via the amplified 3.5mm headphone output. There is also an additional analog output on a PCB connector. Another PCB connector allows to connect a DSP module to the DAC2 Pro.
1 | GPIO Input |
2 | DSP Extension (DSP board not included) |
3 | Analog output |
4 | Line output |
5 | Headphone output |
This connector can be used to connect an external module, such as an amplifier. This output is connected in parallel with the RCA output.
+5V | 1 | 2 | R |
GND | 3 | 4 | GND |
+5V | 5 | 6 | L |
Product type | PCM5122 DAC board |
Input | GPIO 40 pins |
Outputs | 1x Stereo ligne RCA 1x Jack 3.5mm headphone output 1x Analog output (PCB connector) |
Compatibility | Raspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero |
Max output voltage | 2.1Vrms |
SNR | 112dB |
THD+N | -93dB |
Frequency response | 10Hz - 70kHz |
Supported sampling rates | PCM up to 24bit 192kHz |
Dimensions | 5.5 x 6.5 x 1cm |
Weight | 20g |
Consumption | < 0.3W |
Input | GPIO |
Output | RCA |
Output | PCB Connector |
Output | Jack 3.5mm |
DAC / ADC Chip | PCM5122 |
Max sampling rate | 192kHz |
