HIFIBERRY DAC2 HD DAC Board for Raspberry Pi Burr Brown 24bit 192kHz
HIFIBERRY DAC2 PRO DAC Board for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC2 HD is a high-end digital to analog converter, dedicated to be used in combination with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B, Zero). It is a sound card for Raspberry Pi optimized to enjoy high quality audio playback at a low price.
Reference : 15645
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
HiFiBerry DAC2 HD
HiFiBerry DAC2 HD Module DAC pour Raspberry Pi Burr Brown 24bit 192kHz
It is based on a Burr Brown conversion chip supporting sampling rates up to 24bit 192kHz PCM. It also embeds a low jitter clock circuit.
The input is on a 40 pin GPIO header and the output is on stereo RCA (line). There is also an additional analog output on a PCB connector. Another PCB connector allows to connect a DSP module to the DAC2 HD.
1GPIO 40 pins input
25V Power supply from Raspberry Pi
3DSP extension connector
4Analog output, 5V access
5Stereo RCA output
Product typeDAC Chip
InputGPIO 40 pins
Outputs1x Stereo RCA
1x Analog output on PCB connector
CompatibilityRaspberry Pi A+, B+, 2B, 3B, 3B+, 4B, Zero
Max output voltage2.1Vrms
SNR123dB
THD+N-108dB @ 44.1kHz, -10dBFs
Frequency response10Hz - 40kHz (-3dB)
Supported sampling ratesPCM up to 24bit 192kHz
Output sampling ratesPCM up to 24bit 192kHz
Dimensions9.5 x 7.5 x 2.5cm
Weight55g
Consumption< 1W
InputGPIO
OutputPCB Connector
DAC / ADC ChipBurr Brown
Max sampling rate192kHz
The HiFiBerry DAC2 HD is a high-end digital to analog converter, dedicated to be used in combination with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B,...
