AUDIOPHONICS DAC USB ES9028Q2M XMOS U208 / Headphone amplifier Class A
DAC USB ES9028 Q2M 32bit / 384kHz / XMOS U208 DSD 256
This 32bit 384Khz DAC offers the latest generation of ESS SABRE ES9028 PRo chips with true balanced outputs and a powerful adjustable digital volume level. With a high quality design and a high-performance Amanero USB input, it offers a first-rate sound performance at a tight budget.
4.4 / 5
Reference : 12558
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Audiophonics ES9028Q2M
DAC USB XMOS XU208 / Headphone amplifier
Audiophonics DAC ES9028Q2M XMOS XU208 / Amplificateur Casque
Built for high definition
This DAC based on ES9028 Q2M 32bit chips offers formidable performance at a reasonable budget. For example, you can control a pair of active studio speakers or a power amplifier thanks to the ESS SABRE volume, the best 32 bit digital volume with 64 bit accumulator on the market.
USB XMOS U208 et 3 high precision clocks
Its USB input of type XMOS U208 triple clock 22.5792Mhz, 24.576Mhz, 24Mhz is of the most powerful with its own dedicated regulation. This DAC offers great precision and exceptional musicality in a contained budget.
A real integrated headphone amplifier Class A
The headphone amplification part uses a noble amplification scheme with 2 pairs of BD140/BD135 transistors offering a frequency response from 10Hz to 35kHz with a signal-to-noise ratio of 95dB. This section is protected by a dedicated DC sensing circuit controlling an OMRON relay.
32 bit DAC with linear power supply
This audio converter features only quality components with film capacitors and a linear power supply with R-Core transformer for low background noise, essential for a modern 32bit DAC. The two operational amplifiers JRC5532DD and Analog OP275 of the circuit are on interchangeable supports DIP 8 allowing at leisure to change the AOP.
AUDIOPHONICS DAC USB ES9028Q2M XMOS XU208 / Amplificateur casque Class A
DACES9028Q2M
THD0.003% (20Hz - 20kHz unweighted)
Frequency response20Hz - 20kHz (+-0.03dB)
Stereo output voltage level2.4V (RCA)
SNR118dB
Figital volumeLow loss from 0dB to -120dB (does not reduce signal-to-noise ratio)
Headphone output 3.5mm stereo jackImpedance between 16 and 600Ω
Sampling ratesPCM up to 32 bits 192kHz, DSD128
USB compatibilityWindows 7, 8, 8.1, 10 (need XMOS 3.34 driver), Mac OS and Linux
ClocksHigh precision triple clocks: 22.5792Mhz, 24.576Mhz, 24Mhz
Linear power supply230V via IEC
Dimensions177 x 132 x 50mm
Weight1.2kg
Unit delivered bare, without cables or accessories and without instructions-
OutputJack 3.5mm
DAC / ADC ChipES9028Q2M
Max sampling rate384kHz
Max sampling rateDSD128
ColorSilver
18 reviews
Presque parfait
Pour le prix, rien à redire.
Bien construit, simple efficace.
Le son est au début froid, après rodage il devient neutre transparent dynamique, la scène sonore s'ouvre.
Avec 2 aop 527 c'est superbe.
Je lui trouve 2 petits défauts :
La puce sabre combiné à ce petit ensemble donne une scène sonore précise mais peu profonde, c'est un peu plat.
Autre point qui me gêne plus, c'est es bruits lorsque l'on change de câble usb et surtout si on l allume en dernier et on leteinds en premier.
Sinon pour le prix merci audiophonics, dommage que la version 9038 audiophonics ne se fasse plus
This review has been posted for AUDIOPHONICS DAC USB ES9028Q2M XMOS U208 / Headphone amplifier Class A
Quoi de plus ?
Ayant fait récemment l’acquisition d’un casque, j’avais passé commande du couple A30/D30 de chez Topping, sur Audiophonics.
Le dac D30 avec sa puce CS ne correspondait visiblement pas à ce que je recherchais. Et cela, que ce soit au casque ou au salon sur les enceintes B&W ou d’autres matériels. L’ampli A30 était bien pour ce que je puisse en juger, connecté à un dac sabre 9023 ou la platine en 9018 du salon. Les dac sabre semble plus correspondre à ce que j’aime.
Ce petit combo 9028 et ampli class A me semblait être une bonne alternative à essayer.
Et bien comment dire, je ne remercierais jamais assez audiophonics de proposer ce type de matériels et surtout à ce prix. Je ne sais pas si d’autres boutiques comme celle-ci existe dans d’autres pays, mais je trouve que de disposer d’une enseigne comme audiophonics en France est une vrai aubaine. Surtout que les envois sont rapides, le site est clair, on dispose de détails sur les matériels …
Je suis conscient que les avis sur le son que produisent ces matériels sont subjectifs. Ce qui plaira à certains ne plaira pas à d’autres, certes. Ce qui suit doit donc être pris avec des pincettes, mais je suis vraiment resté assis lors des premières écoutes.
Des frissons dans tout le corps, je ne sais pas ce qui apporte le plus, la puce en 9028, l’ampli en class A ou la combinaison des deux, mais je suis vraiment resté scié.
Je ne suis pas un habitué des casques, j’étais avant surtout porté sur le couple ampli/enceintes dans un salon non traité (donc pas idéal), mais c’est la première fois que ça me fait ça toutes écoutes confondues.
Bref au casque, je n’ai pas testé la sortie RCA, c’est à la fois détaillé et les voix, les guitares sèches/électrique, tout prend vie, même l’électro prend de l’ampleur.
Encore une fois, cela correspondant peut-être aussi à ce que j’attendais comme « son » et mon avis est très positif, mais il est à mettre en relation avec le prix de « l’objet »
J’en viens à me demander ce que l’on peut vraiment espérer de matériels qui se vendent à des milliers d’euros … et le plus drôle, c’est qu’il y a justement quelques milliers d’euros dans le salon entre les amplis, les enceintes … et la claque … ben elle était au bout d’un ampli/dac à 130 euros et d’un casque fidelio X2HR de Philips à peu près au même prix …
Pour conclure, merci audiophonics
Le DAC qui vous ruine pas
Bonjour,
2 mois se sont écoulés depuis mon achat et j’avais envie de compléter mon avis du 13/01/2020 sur ce dac.
Sortie Casque avec un AKG702 :
Avec une moyenne de 2 heures d’écoute par jour, le son métallique du tout début a complètement disparu après environ 1 mois. Toujours aussi analytique et toujours aussi neutre, mais avec en plus une transparence évidente. L’AOP jrc5532 qui s’occupe de la sortie casque est vraiment une référence. Cependant, selon moi, il est fait pour composer et pour produire de la musique, plutôt que pour l’écouter et l’apprécier. Il ne me transporte pas.
Certes, tout est correcte, tout est à sa place, mais ce n’est pas musical, ce n’est pas entrainant.
J’ai pensé à changer cet AOP pour un OPA1622 qui selon mes recherches est conçu spécifiquement pour les sorties casques.
Sortie ligne vers un Marantz PM5005 et des focal chorus 706 V :
Bon, cet OP275 est vraiment une aberration. C’est tout l’inverse du 5532, il a une equalisation prononcée et claire en forme de V, comme si vous mettez la preset Rock sur un lecteur de fichier audio : basses et aigus augmentés, medium en retrait. De plus, sur les basses, il me donne l’impression que c’est lent, c’est paresseux, que ça tarde à sortir.
Si vous écoutez beaucoup de rock des années 80, vous allez aimer ! Autrement, un remplacement me semble evident.
J’ai pensé à changer cet AOP pour un OPA627 qui selon mes recherches s’avère être l’une des références en la matière.
Petite remarque sur le pilote Win10 en téléchargement sur ce site : il est plus stable que celui qu’on trouve sur le site de Xmos, mais la prise en charge du DSD en natif n’est pas systématique avec tous les lecteurs (Foobar : oui, Jriver : non ).
Pour conclure, cet appareil est sans doute un très bon dac et surtout un très bon amplificateur casque. Il offre en plus la possibilité de changer la signature sonore selon les gouts de chacun.
Vivement la date de réception des nouveaux AOP :-)
2 mois et la prise casque ne tient plus
bonjour
je suis moyennement satisfait, acheté en novembre 19, janvier 20 la prise de casque ne tient plus, elle sort toute seule, le poids du câble spirale 3m du casque DT990pro suffit à arracher la prise...
Bonjour,
Reçu il y a 2 semaines, utilisation avec un AKG 702.
1 - Le produit : tout en aluminium, très bien fini et très bien monté. Les composants sont très bien présentés et je ne retrouve pas de composants reconditionnées. Tout semble d'origine et neuf.
2 - L'installation :
- Windows 10 : build 1909, directement reconnu, j'ai pu sans difficulté le faire fonctionner en bitperfect avec foobar et le plugin asio avec les fichier HD sauf le dsd.
Après l'installation du pilote en téléchargement sur audiophonics.fr, les choses ne s'améiolrent pas , toujours des sifflement et des bip avec le dsd.
J'ai installé les pilotes disponible sur le site de xmos, et là tout fonctionne : tout passe sans accro du simple mp3 au dsd et en natif.
- ubuntu 18.04 : reconnu directement et fonctionne mieux que sous windows . Pour avoir du DSD en natif, il faut choisir le bon kernel
3 - L'écoute : ayant vécu plusieurs temps avec un dac AKM, le son m'a paru sec et métallique , je m'y attendais un peu car j'ai lu beaucoup de commentaires sur les puces ESS. Mais quelle précision !!!!
J'ai perdu un peu de la musicalité des dac AKM, mais j'ai gagné en précision.
Les 2 sorties casques et lignes sont trés différentes. La sortie ligne avec l'aop OP275 perd de l'image stereo par rapport à la sortie casque et son JRC5532, mais gagne en finesse et douceur dans les aigus. La sortie casque est faite essentiellement pour piloter tout genre de casque : puissance, equilibre, bonne image stereo, bonne profondeur, mais manque de musicalité.
Conclusion : Au final je ne peux qu'être satisfait de ce DAC exceptionnel. Il lit tout sans changer de configuration à chaque fois. Meme si le son d'origine est un peu froid, il commence à s'attendrir au fil des heures, mais surtout, on a toujours la possibilité de changer les aop pour changer de signature sonore.
donc le bonheur est double : à l'utilisation et à l'évolution :-)
This 32bit 384Khz DAC offers the latest generation of ESS SABRE ES9028 PRo chips with true balanced outputs and a powerful adjustable digital...
