AUDIOPHONICS USB BALANCED DAC ES9038PRO XLR 32bit/384kHz DSD 128 AMANERO TCXO
TOPPING D30 USB DAC 24bit/192kHz DSD 128 XMOS CS4398
This Audiophonics 32-bit 384Khz DAC 32bit DAC offers the latest generation of SABRE ES9038 PRo ESS chipset with true balanced outputs and a powerful adjustable digital volume level. Featuring a high quality design with a high-performance Amanero USB input, it offers a first-rate sound performance at a tight budget.
By buying this product you get 39 loyalty points
Reference : 12449
390,83 €tax excl.
Including 0,04 € for green tax
Available
Shipping date: 26-08-2019.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
 - HIGH QUALITY BALANCED USB ES9038 PRO DAC -
amanero Es9028 pro
Only for Connoisseur
This DAC offers a formidable range of services at a reasonable budget. Equipped with a truly balanced DAC output schematic with two XLR symmetrics, you can control for example a pair of active studio speakers or a power amplifier thanks to the ESS SABRE volume, the best digital volume on the market.
This DAC incorporates the best 32-bit decoding chip currently available. The ES9038 PRO chip is the decoder par excellence respecting every detail of the essence of music with a timbre quality and harmonic beauty previously unknown on Delta Sigma DACs competing with R2R DACs.
USB Amanero and  TCXO clocks
 amanero es9028 pro
Its dual-clock Amanero USB input with galvanic isolation is the most powerful one using a programmable FPGA and not an already integrated chip. Using a TCXO 100Mhz 0.1PPM TCXO clock with its own dedicated regulation, this DAC offers a high level of precision coupled with outstanding musicality in a contained budget.
A real balanced analogic ouptut DAC
The analog outputs are really balanced since the conversion and comply with the ESS specifications with a "Differential Quad" scheme allowing a high dynamic range, a great reduction of background noise. All 6 AOP LM49990s on the circuit are on interchangeable DIP 8 holders, allowing you to change the AOPs at your leisure by more efficient models. In addition, the power supply has 10 LDO and low-noise group controls that guarantee a high-purity signal even on small details and harmonics.
Remote control ES9038Pro
Technical caracteristics
  • Spécifications :
    • DAC USB 32bit 384Khz
    • Sensibity Digital Input : 0.5V p-p ( 75 Ohm Coaxial ) 19dB sur l'optique Toslink
    • Total harmonic Distortion : 0.003% sur 20 à 20Kh
    • Frequency response : 20 à 20Khz +/- 0.03dB
    • Stereo Voltage output : 2.4V ( RCA )
    • Stereo balanced Voltage Ouput : 5V ( XLR )
    • Noise dynamic ratio : 122dB
    • Digital volume ESS 32bit low distorsion  0dB to -120dB
    • Saving the selected source
  • Sampling frequency Digital Input :
    • USB : PCM 44.1kHz - 384kHz 16-32 bits
    • USB DSD : DSD64 à DSD128
    • SPDIF coaxial input : 24bit max 44.1 Khz -192Khz (DSD DOP64)
    • SPDIF optical input : 24 bit max 44.1Khz - 192Khz (DSD DOP64)
    • USB compatible : Windows 7, 8, 8.1, 10 ( Amanero driver needed ) Mac OS 10 et Linux
    • Digital filter  : Fast and Slow with linear phase ou medium, Apodizing, Hybrid and Brickwall
  • Horloge interne :
    • High precision double clock 22.57Mhz and 24.57Mhz
  • Power needed :
    • Power : 230V  on IEC connector
  • Various :
    • Dimensions : 218 x 199 x 60mm (LxPxH)
    • Weight : 1.5kg
    • One ceble USB 1.5m, one remote, power cable not include
InputUSB Amanero
DAC ChipES0938PRO
Max sampling rateDSD128
Max sampling rate384kHz
ColorSilver
Components / ChipES9038PRO
MaterialMetal
Channel2 channels (Stereo)
Colissimo - TNT - SoColissimo
2 reviews
Excellentisime
Serte il ne fait que DAC, mais il le fait superbement bien.
Il est venu remplacer un TEAC UD 503, réputé pour être un excellent DAC mais ce modèle AUPHONICS le surpasse.
Les basses sont plus franches et descendent un peu plus bas avec beaucoup de tenu. Les aigus sont très clair et détaillés quand aux médiums ils font ressortir les voix avec beaucoup de justesse et de présence sans être trop en avant.
La qualité de fabrication est sans reproche, ce qui en fait un excellent rapport qualité/prix.
BRAVO
This review has been posted for AUDIOPHONICS USB BALANCED DAC ES9038PRO XLR 32bit/384kHz DSD 128 AMANERO TCXO
Great Buy!
Very well built machine, solid cabinet and extremely good components chosen to back up the already good ES9038Pro.
Great option to change the OPAs on board.
Setup took 5 minutes using a Raspberry PI running moOde OS.
I was coming from a Raspberry PI + Hat using a ES9018K2 chip and immediately noticed a dramatic improvement in the quality of the sound.
I then opted to change the already good OPAs and try the Darkos Lab and the end result is amazing!
Sound is crystal clear, open and natural. The speed at transients and bass frequencies is outstanding and the overall tonal balance sounds just right. Soundstage and depth is improved to a new level.
Highly recommended either in its original form or with the new OPAs.
Well done guys!!!!
This Audiophonics 32-bit 384Khz DAC 32bit DAC offers the latest generation of SABRE ES9038 PRo ESS chipset with true balanced outputs and a...
