FX-AUDIO DAC-X6 MKII DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24Bit 192kHz Black
Compact and affordable DAC / headphone amplifier offering excellent audio performance for its price range. Support Bluetooth 5.0 with apt-x protocol.
4.5 / 5
Reference : 14524
69,90 €tax incl.
58,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
DAC-X6 MKII
FX-Audio X6 MKII is an ideal solution for your compact, affordable and high-performance audio systems. It works both as a DAC with volume control and headpthone amplifierand offer multiple ways to connect to various devices (USB, Coaxial, Optique & Bluetooth).
Its analog and digital circuits use high quality components to achieve great audio reproduction in its price range. More specifically it works with an excellent ESS SABRE ES9018 conversion chip. and has a Bluetooth 5.0 QCC3008 interface which supports apt-X protocol.
High quality digital / analog circuit
At the heart of the device is a digital to analog conversion chip ES9018 with Hyperstream achitecture and frequency / time correction digital filters. This technology is particularly famous for its ability to limit distortion and jitter to respect your audio files down to the smallest detail.
In this configuration the X6 MKII offers a rich and detailed sound with PCM audio files up to 192kHz - 24bit.
Its analog stage is equiped with a OP275 operating amplifier  (dual-bipolar / JFET) and a OP2134 (FET) offering a considerable headroom on its RCA output.
The headphone output uses a TPA6120 high fidelity amplifier with considerable power  (940mW @16ohm)
capable of supporting models of headphones that are usually too demanding for standard audio equipment.
Wired and non-wired connectivity
The DAC X6MKII has a USB input on a USB-B connector controlled by a CM6642 interface. The latter allows it to work directly with  audio streams from your computer. This USB connector is not used for powering the X6-MKII, which will avoid most of the typical audio noise if your PC does not have an isolated USB interface.
The device also offers two S / PDIF inputs on Coaxial and Optical connector which open many possibilities for integration with your different digital audio sources (TV, game console, CD player ... ect.)
Finally, a QCC3008 interface allows the DAC X6-MKII to directly receive the audio stream from all your devices equipped with Bluetooth connectivity. Its reception circuit is in Bluetooth 5.0 standard and supports apt-X protocols for redoubled audio precision.
A short pression on the button located on the front panel is all it takes to switch input sources. Two set of LEDs keep the user informed of the active source as well as the current sampling rate.
Its RCA Stereo output with 2Vrms level is used to connect the DAC X6 MKII with a preamplifier, a power amplifier or active speakers.
A second 6.35mm jack connector located on the front of the device allows you to easily connect your headphones.
Product typeDAC with volume control
Headphone amplifier
Max sampling rate24bit 192kHz
Output levelRCA : 2Vrms
Output power (Headphone)940mW@16Ω
900mW@32Ω
700mW@64Ω
450mW@120Ω
InputsUSB-B
Optical
Coaxial
Bluetooth
OutputsStereo RCA
Jack 6.35mm
Power SupplyDC 12V 1A (included)
Bluetooth5.0 with aptX support
THD+N (Headphone)0.006%
SNR (Headphone)112dB
Frequency response (Headphone)+0 / -0.5dB(20Hz-20kHz)
Dimensions11.7 x 17.8 x 3.6cm
Package1x DAC-X6 MKII Black
1x Power adapter 12V
OutputJack 6.35mm
DAC / ADC ChipES9018
Max sampling rate192kHz
ClassN/A
11 reviews
Rapport Qualité Prix !
J'utilise principalement le Bluetooth, que je trouve performant,
par rapport à d'autres appareils utilisés antérieurement.
Dac simple et fonctionnel.
Une petite réserve quant à la puissance de sortie casque.
This review has been posted for FX-AUDIO DAC-X6 MKII DAC Headphone Amplifier Bluetooth 5.0 aptX ES9018 QCC3008 24Bit 192kHz Black
Honnête DAC
Pour un tarif inférieur à 100 euros,appareil très complet en possibilité de connection:utilisé en coaxial sur platine ,en usb pour écouter de la musique en streaming:son agréable, belle image stéréo
Essaye en Bluetooth : forcément c'est très moyen,pour ma part sans interet
Gros point negatif:le bloc d'alimentation 12 volts de qualité très médiocre,avec en plus un câble très court
J'ai pour ma part récupére une alimentation avec un transfo classique à enroulements:plus de précision et de clarté
Fonctionne parfaitement et très facile d'utilisation
J'ai acheté ce DAC pour écouter de la musique à partir de différents appareils Bluetooth et aussi via l'entrée USB par PC et l'entrée optique pour ma TV. Connexion Bluetooth très rapide et simple. La qualité sonore est très bonne avec une légère atténuation des graves que je compense sur le réglage des basses de mon ampli donc pas gênant pour moi. Connexion au PC sans aucun soucis et très bonne qualité audio. J'ai aussi fait un essai de connexion par la prise USB-C de mon Galaxy S9 via un adaptateur OTG connecté à l'entrée USB du DAC. Ça fonctionne nickel avec une super qualité audio. J'ai essayé mon lecteur audiophile FIIO X3 II vers l'entrée USB et via OTG mais là ça ne fonctionne pas. Rien de problématique puisque dans ce cas je peux utiliser la sortie COAX digitale de mon FIIO vers l'entrée COAX du DAC. Donc je suis ravi de mon achat.
Produit de qualitè
Bonjour Très satisfait de ce produit utilisé comme convertisseur numèrique analogique sur la sortie son optique de ma smart tv Samsung
Le niveau du volume sur un ampli muticanal est très peu diminué et sur un ampli intégrè parfait
Le service livraison est au top et le sérieux Audiophonics également
Merci
SAV AUDIOPHONICS AU TOP
cet avis est juste un retour sur le SAV Audiophonics car j'ai déjà mis un avis sur ce produit. Mais comme depuis mon avis j'ai eu un petit souci, ça m'a permis de constater que le SAV de Audiophonics est au top. J'ai reçu des réponses ultra rapides et concises, une proposition de prise en charge du retour du produit et un retour chez moi avec un produit qui fonctionne à nouveau très bien. Souvent via le net on aime bien allumer quand ça se passe pas bien et on oublie de dire quand c'est bien, là, le SAV merci ! je sais chez qui j'irai quand j'envisagerai un nouvel achat audio.
Compact and affordable DAC / headphone amplifier offering excellent audio performance for its price range. Support Bluetooth 5.0 with...
