TOPPING DX7s 2xES9038Q2M DAC / Preamplifier / Headphone ampli DSD 32bit / 768kHz Symetrical Silver
TOPPING DX7s 2x ES9038Q2M DAC / Preamplifier / Headphone ampli DSD 32bit / 384kHz Symetrical
The Topping DX7s is a versatile device that will serve you both DAC, preamplifier and headphone amplifier. It incorporates a symmetrical design based on two DAC ES9038Q2M for exceptional playback.
By buying this product you get 40 loyalty points
Reference : 13859
409,00 €tax incl.
340,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Topping DX7 2XEs9038Q2M
Versatility and efficiency
The Topping DX7s with its "form factor" and its 32bit 768kHz capabilities offers many configuration possibilities. Combining the functions of DAC, digital preamplifier and high impedance headphone amplifier, it will meet most needs with a high-performance balanced headphone output.
USB Dual XMOS ES9038Q2M
The fully symmetrical design of this DAC based on Es9018Q2M 2 chips gives it high technical qualities with crosstalk and insignificant floor noise. Each conventional PCM SPDIF digital input has a galvanic isolation transformer. The Topping Dx7s offers at a studied price of the services rarely reached.
Dual-stage analog real symmetric
Topping DX7s
The analog placement of this DAC is symmetrical to the output of Both ES9038Q2M. The analog portion features separate OP amps For Each left and right audio quality original Texas Instrument channel.
A Balanced HiFi Headphone section
Topping DX7s balanced output
The DAC headphone Topping DX7s offers optimum performance thanks to two TPA6112A2 amps. In addition to Supporting the DSD / DXD and sampling rates of up to 32bit / 768kHz, it benefits from a similar course PARTICULARLY output neat That can attack the market-leading audiophile headphones was 4 pin XLR symmetrical output.
This Allows the DX7 to offer a lower color tone and consequently a faithful reproduction, has very low distortion and a great linearity. You gain in dynamics, details and neutrality.
Topping DX7 Connectiques
CONNECTORS: INPUTS
1x USB XMOS16 - 32bits DSD64 to DSD512 (DOP) / 768kHz
1x Coaxial75Ω 16 - 24bits 44.1kHz - 192kHz
1x Toslink Optical16 - 24bits 44.1kHz - 192kHz
1x AES/EBUBalanced 110Ω 16 - 24bits 44.1kHz - 192kHz
Connectors: Outputs
1x RCA-
1x XLR Symmetry-
1x Coaxial Digital75Ω 16 to 24 bits 44.1kHz to 192kHz
1x Headphone OutJack 6.35mm
1x balanced XLR headphone output4 pins
Report ifgnal noise114dB
crosstalk-130dB to 1kHz
Headphone output level 6.3516Vpp
Balanced headphone output level31Vpp
Fixed2V RMS
Headphone output impedance10Ω (20Ω symmetrical)
Line output impedance DAC100Ω
Line output impedance XLR200Ω
Coaxial Input Sensitivity0.5V pp (75Ω)
Frequency Response20Hz - 20kHz (-0.2dB)
Headphone output power
Asymmetrical Jack 6.35mm690mW to 32Ω, 110mW to 300Ω (16 to 300Ω)
Symmetrical XLR 4 pins420mW to 300Ω, 210mW to 600Ω (16 to 600Ω)
CompatibilityWindows, Mac
Consumption12W
Weight1.95kg
Dimensions250 x 205 x 50mm
Accessories3.5mm Jack, 1x USB Cable, 1x Power Cable / Remote control available as accessories
InputXLR
OutputJack 6.35mm
ColorSilver
Remote ControlYes
3 reviews
great sound...thanks audiophonics
This review has been posted for TOPPING DX7s 2xES9038Q2M DAC / Preamplifier / Headphone ampli DSD 32bit / 768kHz Symetrical Silver
Habitué par le rendu d'une carte Asus Essence STX + casque AKG701
le son de ce DAC est d'une clarté et précision diabolique
les 3 bandes grave/medium/aigue occupe parfaitement tout le spectre sans débordement
révélateur du moindre détail d'une piste audio,
et cette sensation d'immersion devient évidente lorsque l'on monte en qualité de fichier.
Boitier de très bonne qualité, molette crantée solide.
A noter, ensemble livré avec un câble d'alimentation prise US et pas d'adaptateur fournis,
une longueur de câble USB plus grande aurait été aussi appréciée.
Bonne surprise!
Première commande, et première bonne surprise, de ce petit DAC TOPPING DX7S arrivé très rapidement et ce malgré les problèmes de confinement! Encore en rodage, le résultat sonore va donc progresser mais déjà, je découvre un beau potentiel musical, je l'utilise sur l'entrée AES via une interface USB, le tout piloté par mon PC.
Merci à l'équipe d'AUDIOPHONICS pour leurs compétences et réactivité exemplaire surtout par ces temps qui courent!!!
Musicalement Richard.
The Topping DX7s is a versatile device that will serve you both DAC, preamplifier and headphone amplifier. It incorporates a symmetrical design...
