Passe quasi parfaitement le test de lecture de l'album Myopia d'Agnès Obel que tant de Dacs massacre. L'ampli n'est pas en reste et fait un très bon travail. Enchanté de mon achat chez Audiophonics
By buying this product you get 36 loyalty points
Headphone Amplifier DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Silver
Topping offers with its EX5 an extremely powerful DAC and headphone amplifier combo. Its conversion stage is indeed based on two ES908Q2M DAC chips and allows the reading of high resolution audio streams, while ensuring an incredible precision and sound richness. Versatile, the EX5 has a complete connectivity as well as a Bluetooth 5.0 connectivity. Its amplification stage, using an NFCA circuit, allows it to deliver a comfortable power to accompany the majority of the headphones of the market while ensuring a perfect audio transparency.
At the heart of the EX5 is a particularly efficient digital to analog conversion stage. Taking advantage of a symmetrical architecture, it uses two ESS ES9038Q2M chips, supporting PCM files up to 32bit 768kHz and DSD up to DSD512. These DACs allow to reach an excellent sound quality, marked by a great precision and a beautiful transparency. This conversion stage is associated with a USB XMOS XU216 interface which is also extremely powerful and allows the decoding of MQA files.
The Topping EX5 supports the decoding and rendering of MQA (Master Quality Authenticated) files. This technology allows to enjoy high quality audio streams, as close as possible to the original studio recording.
The EX5 embeds a Bluetooth 5.0 Qualcomm CSR8675 chip. It is thus possible to broadcast your music remotely directly from your smartphone for example. In addition, this Bluetooth chip supports the high-resolution codecs aptX, aptX HD, aptX LL and LDAC, allowing you to achieve a very good quality of sound reproduction in Bluetooth.
The Topping EX5 has four outputs: one unbalanced headphone output on 6.35mm jack, one balanced headphone output on 4-pin XLR, and two line outputs on unbalanced RCA and balanced XLR. It is thus possible to define an output mode among four available: headphone output only, RCA only, XLR only or XLR + RCA. This selection allows the EX5 to adapt to different types of use. Regardless of the output mode, the volume control remains effective.
Product type | DAC Headphone amplifier |
Inputs | 1x USB-B 1x Optical Toslink 1x Coaxial Bluetooth 5.0 |
Outputs | 1x Single-ended RCA 1x Balanced XLR 1x Single-ended Jack 6.35mm headphone output 1x Balanced XLR 4 pins headphone output |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX LL, aptX HD, LDAC |
DAC (@ Line out/USB, 96kHz) | |
THD+N @ A-Weighting | RCA : < 0.0001% @ 1kHz XLR : < 0.0001% @ 1kHz |
THD @ No-Weighting, 90kBw | RCA : < 0.0005% @ 20Hz-20kHz XLR : < 0.0004% @ 20Hz-20kHz |
SNR @ A-Weighting | RCA : 125dB @ 1kHz XLR : 125dB @ 1kHz |
Dynamic range @ A-Weighting | RCA : 125dB @ 1kHz XLR : 125dB @ 1kHz |
Frequency response | RCA : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB) XLR : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB) |
Output level | RCA : 2.1Vrms @ 0dBFS XLR : 4.3Vrms @ 0dBFS |
Noise @ A-Weighting | RCA : < 1.7µVrms XLR : < 2.5µVrms |
Crosstalk | RCA : -85dB @ 1kHz XLR : -85dB @ 1kHz |
Channel balance | RCA : 0.3dB XLR : 0.3dB |
Output impedance | RCA : 100Ω XLR : 200Ω |
Headphone amplifier (@ USB, 96kHz) | |
THD+N @ 1kHz A-Weighting | Jack 6.35mm : < 0.0001% @ 145mW 32Ω / < 0.0001% @ 15mW 300Ω XLR 4 Pins : < 0.0003% @ 145mW 32Ω / < 0.00015% @ 15mW 300Ω |
THD @ 20Hz-20kHz 90kBW | Jack 6.35mm : < 0.00015% @ 145mW 32Ω / < 0.00015% @ 15mW 300Ω XLR 4 Pins : < 0.0004% @ 145mW 32Ω / < 0.0002% @ 15mW 300Ω |
SNR @ Max out, 1kHz, A-Weighting | Jack 6.35mm : 125dB XLR 4 Pins : 125dB |
Dynamic range @ 1kHz A-Weighting | Jack 6.35mm : 125dB XLR 4 Pins : 125dB |
Frequency response | Jack 6.35mm : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB) XLR 4 Pins : 20Hz-20kHz (±0.1dB) / 20Hz-40kHz (±0.3dB) |
Output level | Jack 6.35mm : 5.9Vpp @ G=L / 18.3Vpp @ G=H XLR 4 Pins : 5.9Vpp @ G=L / 18.3Vpp @ G=H |
Noise@ A-Weighting | Jack 6.35mm : < 1.5µVrms @ G=L / < 3Vrms @ G=H XLR 4 Pins : < 1.5µVrms @ G=L / < 3Vrms @ G=H |
Diaphonie @ 1kHz | Jack 6.35mm : -88dB XLR 4 Pins : -99dB |
Gain | Jack 6.35mm : G=L 6dB (Vrms/FS) / G=H 16dB (Vrms/FS) XLR 4 Pins : G=L 6dB (Vrms/FS) / G=H 16dB (Vrms/FS) |
Channel balance | Jack 6.35mm : 0.3dB XLR 4 Pins : 0.3dB |
Output impedance | Jack 6.35mm : < 0.1Ω XLR 4 Pins : < 0.1Ω |
Output power | Jack 6.35mm : 2x 1.3W @ 32Ω THD+N<1% / 2x 140mW @ 300Ω THD+N<1% XLR 4 Pins : 2x 1.3W @ 32Ω THD+N<1% / 2x 140mW @ 300Ω THD+N<1% |
Headphone impedance recommended | Jack 6.35mm : 16-600Ω XLR 4 Pins : 16-600Ω |
Supply voltage | 100-240VAC 50Hz/60Hz (power cable included) |
Dimensions | 17.4 x 13.8 x 4.5cm |
Weight | 750g |
Color | Silver |
Package | 1x Toppping EX5 1x Remote control 1x USB cable 1x Jack 6.35mm to Jack 3.5mm adapter 1x Bluetooth antenna 1x Power cable |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | XLR |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Silver |
Class | N/A |
Networking | No |
Remote Control | Yes |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe V.
Philippe V.
