AUDIOPHONICS USB BALANCED DAC ES9038PRO XLR 32bit/384kHz DSD256 AMANERO TCXO I2S
TOPPING D30 USB DAC 24bit/192kHz DSD 128 XMOS CS4398
This Audiophonics 32-bit 384Khz DAC 32bit DAC offers the latest generation of SABRE ES9038 PRo ESS chipset with true balanced outputs and a powerful adjustable digital volume level. Featuring a high quality design with a high-performance Amanero USB input, it offers a first-rate sound performance at a tight budget.
Reference : 12449
469,00 €tax incl.
390,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
 - HIGH QUALITY BALANCED USB ES9038 PRO DAC -
amanero Es9028 pro
Only for Connoisseur
This DAC offers a formidable range of services at a reasonable budget. Equipped with a truly balanced DAC output schematic with two XLR symmetrics, you can control for example a pair of active studio speakers or a power amplifier thanks to the ESS SABRE volume, the best digital volume on the market.
This DAC incorporates the best 32-bit decoding chip currently available. The ES9038 PRO chip is the decoder par excellence respecting every detail of the essence of music with a timbre quality and harmonic beauty previously unknown on Delta Sigma DACs competing with R2R DACs.
USB Amanero and power filter
Its dual-clock Amanero USB input with galvanic isolation is the most powerful one using a programmable FPGA and not an already integrated chip. Using a TCXO 100Mhz 0.1PPM TCXO clock with its own dedicated regulation, this DAC offers a high level of precision coupled with outstanding musicality in a contained budget.
A real balanced analogic ouptut DAC
Balanced DAC
The analog outputs are really balanced since the conversion and comply with the ESS specifications with a "Differential Quad" scheme allowing a high dynamic range, a great reduction of background noise. All 6 AOP LM49990s on the circuit are on interchangeable DIP 8 holders, allowing you to change the AOPs at your leisure by more efficient models. In addition, the power supply has 10 LDO and low-noise group controls that guarantee a high-purity signal even on small details and harmonics.
Remote control ES9038Pro
Technical caracteristics
  • Spécifications :
    • DAC USB 32bit 384Khz
    • Sensibity Digital Input : 0.5V p-p ( 75 Ohm Coaxial ) 19dB sur l'optique Toslink
    • Total harmonic Distortion : 0.003% sur 20 à 20Kh
    • Frequency response : 20 à 20Khz +/- 0.03dB
    • Stereo Voltage output : 2.4V ( RCA )
    • Stereo balanced Voltage Ouput : 5V ( XLR )
    • Noise dynamic ratio : 122dB
    • Digital volume ESS 32bit low distorsion  0dB to -120dB
    • Saving the selected source
  • Sampling frequency Digital Input :
    • USB : PCM 44.1kHz - 384kHz 16-32 bits
    • USB DSD : DSD64 à DSD128
    • SPDIF coaxial input : 24bit max 44.1 Khz -192Khz (DSD DOP64)
    • SPDIF optical input : 24 bit max 44.1Khz - 192Khz (DSD DOP64)
    • I2S Input : 32bit / 384kHz / DSD256
    • USB compatible : Windows 7, 8, 8.1, 10 ( Amanero driver needed ) Mac OS 10 et Linux
    • Digital filter  : Fast and Slow with linear phase ou medium, Apodizing, Hybrid and Brickwall
  • Horloge interne :
    • High precision double clock 22.57Mhz and 24.57Mhz
  • Power needed :
    • Power : 230V  on IEC connector
  • Various :
    • Dimensions : 218 x 199 x 60mm (LxPxH)
    • Weight : 1.5kg
    • One ceble USB 1.5m, one remote, power cable not include
DAC / ADC ChipES9038PRO
Max sampling rateDSD128
Max sampling rate384kHz
ColorSilver
5 reviews
DAC USB extraordinaire
Il est compact, possède des sorties asymétriques et symétriques contrôlables en même temps par les mêmes boutons + et - . Pour moi c'est le top, la sortie asymétrique est relié vers un petit ampli 2 X 15 W qui modules des enceintes de 96 db pour 1 W à 1 m, largement pour jouer du piano en appartement ! et L'entrée symétrique est reliée à une UI 16 de mixage virtuelle de chez Soundcraft, pour du mixage en une amplification plus musclée en salle, ou une écoute au casque lorsque je travaille tard le piano pendant les périodes où mes voisins se reposent. C’est parfait !
Le seul souci pour moi est de voir qu'à peine acquis cet appareil n'est déjà plus disponible à la vente par Audiophonics !?
J'aurais aimé en acquérir un second en secours si par malheur celui-ci venait à avoir des soucis.
Pourquoi ? J'ai fait un petit meuble où tout a sa place, donc en cas de souci impossible de trouver le même appareil pour le même encombrement.
Cet appareil à une réponse impulsionnelle rapide, précise et totalement haute définition. Le rendu des harmoniques est splendide.
J'invite Audiophonics à me donner une réponse à cette remarque, afin de savoir s'il sont capables de m'en reproduire une second de même acabit et avec les même fonctions qui me suffisent amplement. Je n'ai pas besoin d'un lecteur de fichiers audio intégré, style spotify ou autre.
Pierre R.
This review has been posted for AUDIOPHONICS USB BALANCED DAC ES9038PRO XLR 32bit/384kHz DSD256 AMANERO TCXO I2S
excellent
Tres tres bon produit.Acheter pour remplacer un dac rega qu'il bat sur tout les plans.les aigus sont tres détaillés mais doux ,le medium est excellent et le grave descend tres bas mais est hyper tendu.Ecouter ALL OVER ME de MARK CURRY (morceau test de la nouvelle revue du son) est une pure merveille. J'utilise les sorties symétriques avec le cable pangeas premium balanced qui apporte encore plus de details.A conseiller sans reserves un produits de toute beauté.Et merci a l'equipe d'audiophonics pour leurs tres bons conseils. Je vais poster un avis sur la carte ELFIDELITY AXF 100 PRO 3 qui est aussi un excellent produit
Très bien. Excellent rapport qualité / fonctionnalité / prix
J'ai acheté ce DAC pour un système de bureau pour une écoute au casque.
La taille est très raisonnable, il se loge assez facilement dans un petit espace.
La qualité de fabrication est également très bonne.
Je trouve que c'est une composition qui va à l'essentiel : puce DAC au top de la gamme, composants de qualité, pas de fonctionnalités inutile, très bon rapport qualité/prix.
Je le connecte en USB au PC équipé d'une carte USB Matrix Elemnt H achetée également sur ce site.
L'ensemble fonctionne parfaitement et c'est très intuitif.
La télécommande est très utile et fait aussi le travail.
Pour la forme j'aurais préféré que les boutons en façade soit un peu plus fins (ou de meilleure qualité tactile), rien de gênant.
Concernant le son, je suis très satisfait, cela dépend bien sur de l'ensemble de la chaine. Toute ma chaine à été construite en même temps donc je ne peut pas comparer, mais si le résultat final est très bon c'est que chaque composant doit être très bon.
Pour conclure, que du bon, aucun regret, si c'était à refaire j'acheterais le même.
Un grand bravo pour le produit et aussi pour la rapidité de livraison et la qualité du service client.
PS : il y a bien une connexion I2S (pas présente sur la photo de l'arrière sur le site me semble-t-il).
Excellentisime
Serte il ne fait que DAC, mais il le fait superbement bien.
Il est venu remplacer un TEAC UD 503, réputé pour être un excellent DAC mais ce modèle AUPHONICS le surpasse.
Les basses sont plus franches et descendent un peu plus bas avec beaucoup de tenu. Les aigus sont très clair et détaillés quand aux médiums ils font ressortir les voix avec beaucoup de justesse et de présence sans être trop en avant.
La qualité de fabrication est sans reproche, ce qui en fait un excellent rapport qualité/prix.
BRAVO
Great Buy!
Very well built machine, solid cabinet and extremely good components chosen to back up the already good ES9038Pro.
Great option to change the OPAs on board.
Setup took 5 minutes using a Raspberry PI running moOde OS.
I was coming from a Raspberry PI + Hat using a ES9018K2 chip and immediately noticed a dramatic improvement in the quality of the sound.
I then opted to change the already good OPAs and try the Darkos Lab and the end result is amazing!
Sound is crystal clear, open and natural. The speed at transients and bass frequencies is outstanding and the overall tonal balance sounds just right. Soundstage and depth is improved to a new level.
Highly recommended either in its original form or with the new OPAs.
Well done guys!!!!
This Audiophonics 32-bit 384Khz DAC 32bit DAC offers the latest generation of SABRE ES9038 PRo ESS chipset with true balanced outputs and a...
