By buying this product you get 86 loyalty points
The DAC YULONG Audio ADA 1 USB 32 bit 384Khz represents the new generation of audiophile converters. Equipped with two AKM AK4490(one per channel) the YULONG Audio ADA 1 has 4 digital inputs for decoding all high-definition stereo signals up to DSD DOP 64/128 and PCM 384Khz.
In addition, this DAC has a digital volume on 80 levelsof high quality to avoid a preamplifier.
The low jitter digital part includes 4 high-precision PLL clocks (less than 50 picoseconds), a USB receiver SAVIAUDIO SA9227, a PLD loop SPDIF receiver SAVIAUDIO SA8804.
The power supply has a toroidal transformerPlitronlow radiation and all the audiophile refinements withLDO regulators low noiseADP124, ADM7150. The numbers speak for themselves with a very low background noise.
A JFET transistor helmet amplification in class A (MJD243 / 253)in 6.25mm jack will do justice to your recordings with discrete components. The Buffer part uses the very good TI OPA1632 low noise amps (slew rate 50Mhz).
The aluminum enclosure of this DAC has a smart front of the most beautiful effect with tactile buttons of volume and source selection. This audio converter possesses true balanced outputs as well as a digital input in AES / EBU 110Ohm format. The headset can be turned off in order to lower the background noise.
General characteristics: YULONG Audio ADA1 32 bit 384Khz AK4490 X2.
Technical characteristics :
Dimensions and weight:
Input | XLR |
Input | Optical |
Input | SPDIF |
Output | XLR |
Output | RCA |
Output | Jack 6.35mm |
DAC / ADC Chip | AK4490 |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Color | White |
Networking | Yes |
Remote Control | No |
