ARMATURE Asterion R2R Balanced XLR DAC 24bit/384khz DSD512 XMOS U208
ARMATURE Asterion R2R Balanced XLR DAC 24bit/384khz USB 3.0 XMOS
The Asterion Frame is designed with great precision in a clean aluminium finish. Every detail and every aspect of the Asterion matches the expectations of the most discerning audiophile. The Asterion Armature Asterion DAC will distil limitless musical pleasure in 24bit 384khz and DSD 512.
By buying this product you get 159 loyalty points
Reference : 12038
1 590,00 €tax incl.
1 325,00 € tax excl.
Available
Shipping date: 19-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Armature Asterion
DAC 24bit 384kHz I2S, Dual Conversion PCM & DSD, R2R linear compensation technology
Armature asterion
Fully discreet, high-precision DAC technology
armature asterion r2r
The heart of the Asterion features digital analog conversion with over 256 high-precision resistors in R2R linear compensation mode. Each bit of high and low weight is saved to bring what makes the very meaning of music. Every inflection, every detail contributes to the musical message in its veracity. Supported by an Altera MAX II processor that lowers the jitter to the limit of measurable, the Asterion Armature DAC respects the digital flow without any aggressiveness, favouring timbre and balance with a coherent and realistic sound scene. In addition, the Asterion offers NOS, PCM oversampling and DSD oversampling modes that perfectly adapt to all musical styles.
armature asterion dsd dxd
Genuine 100% native R2R DSD conversion
armature asterion r2r dsd natif
Unlike many DACs, even the most advanced R2R technology, the Asterion Armature has a separate R2R DSD section from the PCM section and therefore dedicated resistors providing real DSD conversion close to the original signal. The Asterion demonstrates its ability to read both 32-bit PCM 384kHz and DSD 512 signals (256 under Windows) with the highest technological capability.
A clever mix between digital and analogue, truly symmetrical
armature asterion numérique et analogique
Truly top-of-the-range, the Asterion is fully balanced from conversion output to analog balanced XLR connectors. The analogue section consisting of Vishay MKP 1871 capacitors has operational input amplifiers and a discrete line buffer stage in pure class A class A entirely in discrete transistors.
This results in a strong current rejection and immunity to noise, followed by a class A stage renowned for its musicality, the speed of its impulse response and low counter reaction.
USB input that respects your music
An analog output stage is nothing without a high definition high performance digital input. The Asterion Armature's USB input interface features the latest generation of XMOS U208 processor, four times the power of a traditional XMOS. This USB card also implements digital galvanic isolation by double isolating bridges, freeing itself from the noise delivered by your computer. It guarantees a lower jitter which is then processed by the ALTERA MAX II processor.
Separately regulated low noise power supply
armature asterion alimentation faible bruit
The oversized power supply of the Asterion DAC Armature has a symmetrical shielded transformer for the digital parts and a "Torus O TYPE" transformer with low magnetic radiation of 100VA. This contributes to the great stability of the sound image and sound scene of this exceptional DAC.
armature asterion schéma
  • A: Conversion section R2R PCM and separate DSD conversion section
  • B: Capacitor power supply section VISHAY MKP
  • C : Low drift high speed diode cross section
  • D : Analogue conversion stage hybrid voltage current conversion PDO and discrete class A hybrid voltage conversion stage
  • E : Class A transistor analog buffer stage
  • F : Digital input board with ALTERA MAX 2 PCM and I2S with isolation (on SPDIF)
  • G : USB digital input card with double galvanic isolation
  • H : A toroidal transformer for analog, a shielded transformer for the digital part
Digital inputs
HDMI LVDS I2S (Audio-GD compatible)1x
RCA Coaxial PCM1x
BNC 75Ω PCM1x
Optical Toslink1x
XLR AES/EBU 110Ω1x
USB XMOS U2081x
Digital outputs
Symetrical XLR 4.5V1x
Asymmetrical RCA 2.5V1x
SNR126dB @ 1000Hz
THD-112dB on 2.5V
High precision dual clock-
Supported sampling rates with RCA, Toslink, BNC et AES/EBUup to 24bit 192kHz
Supported sampling rates with I2S et USBup to 32bit 384kHz
Dimensions430 x 300 x 55mm
Case materialAluminium
Weight8.5kg
Power Supply230V
ComponentDAC R2R
InputUSB XMOS
MaterialAluminium
ColorNoir
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
The Asterion Frame is designed with great precision in a clean aluminium finish. Every detail and every aspect of the Asterion matches the...
