ARMATURE PHOBOS AB Integrated Amplifier 2x300W / 4 Ohm USB DAC Pre-out
ARMATURE PHOBOS Amplificateur DAC USB 24bit/192khz
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex loads.
4.6 / 5
By buying this product you get 139 loyalty points
Reference : 11957
1 390,00 €tax incl.
1 158,33 € tax excl.
Shipping from France
Billing in France
Technical support in France
Armature Phobos
Armature Audio Phobos
2 x 300W Class AB Amplifier + DAC 24bits 192kHz Armature Phobos
Power and control
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex loads. High-performance loudspeaker enthusiasts or faithful studio monitor libraries, Phobos is the answer with a large number of analog and digital inputs.
Armature Phobos
Qobuzissime for the ARMATURE PHOBOS
Discover the complete and detailed test of the PHOBOS amplifier, which has been awarded a Qobuzissime for its quality and high performance (click on the banner below).
Qobuzissime Armature Phobos
A true digital HUB of 2x300W under 4 Ohm
The PHOBOS Audio Armature is the aliasing of digital and analog. It has a 24 bit 192kHz DAC with USB input CMEDIA, SPDIF coaxial, BNC, optical and 3 analog inputs including a balanced XLR input. It also has a variable pre-out output and a fixed DAC-out output.
The Phobos amplifier meets all operating scenarios. Armature Phobos
Armature Phobos
A genuine DAC 24bit 192kHz
The central card of the phobos includes a DAC Ti PCM1794 ensuring true digital analog conversion work of quality. Featuring a symmetrical dedicated power supply with a filtering capacity of 52800μF to 35V, a jitter bucker SRC4392, four LDO regulators and analogue output AOP LT1028, the Phobos DAC concentrates the best of technology in a single device .
A real comfort of use.
Thoughtfully, the Phobos remote control allows full control with pre-out, or an integrated amplifier mode, or both simultaneously. The PHOTO's DOT Matrix LED display provides real legibility without the aggressiveness of the main functions of the amplifier.
Armature Phobos
Armature Phobos
Connectors: Digital Inputs
RCA SPDIF1x
BNC SPDIF1x
Optical Toslink1x
USB 2.01x
Connectors: Analog Inputs
RCA 2x
XLR balanced1x
Connectors: Outputs
Pre OutStereo RCA (variable)
Line Outputs DAC LineNot affected by input selected (Fixed volume)
Power output2 x 300W 4ohm
2 x 150W 8ohm
Signal Ratio> 115dB
THD0.004%
Frequency Response20Hz - 70kHz (at -3dB)
Output Impedance0.025 ohms / Damping Factor : 160 @4ohm - 320 @8ohm
Max Output Level2.5V (RCA) / 4.5 XLR Symmetrical
Input sensitivity0.5Vp-p (Coaxial, 75Ω) / 19dBm (Optical)
24-bit sampling
USB (CM6631A)44.1kHz up to 192khz
Coaxial44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz
Optical44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz
Miscellaneous
Dimensions425 x 325 x 105mm
chassis100% Aluminum
Weight18.6kg
AccessoriesPower cord, aluminum remote control
InputBNC
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)300.0
5 reviews
excellent
Cet ampli est vraiment extra !
Il fait mieux que feu mon audio analogue puccini settenta rev2.0. Les graves sont puissants et prenants mais non envahissants. La précision des aigu reste excellente sans jamais etre agressive. Les médiums son justes et precis. Les bas-medium (ex voix de crooner) sont peut etre légèrement en retrait de l’excellente qualité du reste du spectre sonore qui est tres spacieuse et assez profonde.
Le DAC intégré est aussi très bon, puissant et tres vivant mais au prix d'une légère agressivité. Rien de dérangeant à des niveaux habituels d’écoute. On pourrait meme dire au contraire cela permet de profiter des timbres à faible db, ca se discute. Avec ce DAC j'ai la aussi remplacé de DAC du lecteur CD paganini (plus doux mais aussi plus fade) maintenant utilisé en driver seul.
Niveau puissance, rien a redire, il y a de quoi avoir mal aux oreilles avant d'atteindre le max (je me suis arrété a -10db avec mes colonnes 3 voix 90db 4 ohm)
En résumé, un excellent produit aux timbres plutot suaves et pleins de douceur. Le DAC est lui plus explosif et dynamique. De mon expérience personnelle (AAnalogue puccini, hegel H80, musical fidelity M3i), le rapport Q/P me parait imbattable, ici on est vraiment à la gamme (voir plusieurs gammes) de dessus.
Pour ma part, avec une entrée phono ce serait le produit idéal mais attention a vos meubles, les 25kg sont a supporter!
Je recommande ce produit et remercie l'équipe Aphonics et Armature pour leur travail.
This review has been posted for ARMATURE PHOBOS AB Integrated Amplifier 2x300W / 4 Ohm USB DAC Pre-out
Beau; puissant et musical !
Mélomane et audiophile depuis une quarantaine d’année, j’ai acquis cet ampli avec l’angoisse de celui qui s’aventure en «la terre inconnue» de l’achat sur internet...
L’envoi du colis a été particulièrement rapide et soigné et la communication des informations émanant du site, suivie et trés professionnelle, ce qui est rare aujourd’hui.
Cet appareil est magnifiquement et ambitieusement construit. Dans les règles classiques de l’art avec des solutions techniques modernes mais éprouvées. Superbe...
A l’écoute, il s’avère sensible aux éléments associés: câbles, électroniques; enceintes, supports; etc... (ici d’une gamme beaucoup plus élevée que la sienne). Son rendu est immédiatement familier, doux et loin d’une écoute anormalement crue et décortiquée.
Il est charnu, souple et onctueux avec une belle richesse de timbres. Il permet de longues écoutes non fatiguantes avec une scène sonore magnifique; ample, précise et profonde, faite de plénitude et de sérénité.
Il incarne une musicalité crédible avec une puissance raffinée et confortable sur tout type musique, de l’opéra à la musique drône/synthétique (jazz, baroque etc...) et rend parfaitement justice à la source qui l’alimente, (pour ma part un lecteur CD coûtant quatre fois son prix).
C’est un appareil pour mélomane qui semble étudié et (ou) assemblé par des gens qui semblent maîtriser (en France) un circuit de distribution hors des chemins habituels empruntés par les importateurs et revendeurs.
J’ai beaucoup acheté ou écouté des appareils fort coûteux de toutes technologies (tubes; FDA, transistors) pour apprécier ce bel et bon ampli qui pour son prix est une aubaine.
Je lui trouve aussi trois défauts:
- une carte convertisseur qui fait le job mais musicalement un peu juste (peut-être n’ai je pas le câble qui lui rendrai justice?)... ;
- une sortie casque absente...;
- une télécommande trés lourde, peu ergonomique..
son angle d’emploi est trop restreint (du plus + classique aurai été aussi efficace).
Pour le reste; merci à Audiophonics de proposer aux mélomanes hexagonaux la souplesse créative du Do it yourself et de son expertise par ses services très pros à travers la marque ARMATURE.
Je ne peux encore mesurer la fiablité de ce produit en souhaitant que la marque assure aussi bien le service après-vente de ses produits. (garantie deux ans).
Bravo!
Philippe C.
Belle Fabrication et Magnifiques Timbres
Après de nombreuses années passées dans le segment High End, j'en ai eu assez de la fuite en avant incessante qu’amène la recherche de la perfection que l’on ne trouve jamais, et je voulais juste m’assoir dans mon canapé pour écouter de la musique et pas mon matériel. Je cherchais depuis longtemps un « petit » intégré capable de faire chanter mes enceintes (des Sonus Faber Guarneri Evolution) et leur 85db, et après de nombreux essais d’intégrés toujours assez haut de gamme (Hegel H300, Moon 600i), j’ai trouvé que le Phobos était très sympa sur le papier, et suite aux bon conseils reçus par échanges d’emails, j’ai finalement décidé de faire le pas pour cet ampli vendu en direct et ne respectant pas le modèle classique Fabricant-Importateur-Revendeur. Et la surprise est vraiment belle pour un ampli au prix relativement modique, le médium aigue est magnifique, le grave bien tendu et timbré, et le DAC fait quasi aussi bien que mon « vieux » Bel Canto 3.7. La scène sonore est large. La qualité de fabrication est également au rendez-vous, l’ampli chauffe peu donc je le laisse « always on ». J’aurais juste aimé que lorsque l’affichage est éteint, il s’allume temporairement quand on monte ou baisse le son, et que la télécommande accepte un angle d’attaque plus large (il faut être plutôt bien en face pour qu’elle fonctionne bien). La connectique est elle aussi de très bonne facture et offre une prise BNC, bienvenue pour brancher mon ALLO DiGiOne (sur PiCorePlayer). Un ampli avec une vrai signature sonore et des timbres très réussis… Attention, le réglage du volume n’est pas linéaire mais logarithmique, donc pour mes enceintes au petit rendement, je dois monter le volume assez haut, mais aucun tassement, au contraire, l’ampli s’exprime très bien.
Décevant
Voila 3 semaines que je teste ce produit et mon avis est plutôt mitigé. Outre une finition extérieure très moyenne et une télécommande mal fichue et trop lourde, l'ampli ne tient pas vraiment ses promesses en terme de puissance.
J'ai la chance de posséder 3 paires d'enceintes et ai donc pu procéder à plusieurs tests.
- Enceintes Klipsch RP-280F + cable Norstone 2x4mm2+ daphile (fichiers FLAC HD Heavy Metal/Rock/ Electro) +cable USB Supra / Lecteur Oppo BDP-103 via sorties analogiques / Chromecast Audio via sortie optique
- Enceintes Klipsch Heresy 3 + cable Norstone 2x4mm2+ daphile (fichiers FLAC HD Heavy Metal/Rock/ Electro) +cable USB Supra / Lecteur Oppo BDP-103 via sorties analogiques / Chromecast Audio via sortie optique
- Enceintes Dali Sensor 3 + cable Norstone 2x2.5mm2+ daphile (fichiers FLAC HD Heavy Metal/Rock/ Electro) +cable USB Supra / Lecteur Oppo BDP-103 via sorties analogiques / Chromecast Audio via sortie optique
Ce qui frappe après de longues heures d’écoute, est la douceur et la precision du son. L'image stereo est ample , les basses présentes et bien définies, le niveau de détails très haut dans toutes les configurations.
La puissance promise n'est par contre pas vraiment au rdv et meme si l'on peut atteindre un niveau d'écoute tout à fait acceptable, on est loin de la 'patate' d'un NuPrime IDA-8 qui pourtant
vaut moins cher. Au final, sans vraiment regretter mon achat, je trouve cet ampli trop cher au vu des performances.
 (6)
Puissance et lisibilité
L'essai publié dans Qobuz avec un Qobuzissime m'a fait craquer. En duo avec mes enceintes Cabasse Iroise 3, la combinaison est remarquable. A recommander sans réserve.
 (3)
 (4)
The PHOBOS armature amplifier fits in with its time. Featuring a generous power stage with a high current capacity Phobos faces the most complex...
