AUDIOPHONICS DAC AK4495SEQ 32bit 192kHz Asynchronous USB XMOS Silver
AUDIOPHONICS DAC AK4495SEQ USB 32bit 384kHz Asynchronous XMOS
4.8 / 5
Reference : 10978
199,00 €tax incl.
165,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Excellent converter, this small case in solid aluminum in very elegant design is equipped with the converter AKM AK4495SEQ coupled to a digital interface AKM AK4118A to very low jitter (50ps).
This DAC 32bit 192Khz has a filtering stage composed of an operational amplifier of high neutrality LME49760HA.
This AOP, renowned for its dynamics and precision, is mounted on an interchangeable DIP8 support to be replaced at your leisure to adjust its sound signature.
Its interface Audiophonics Xmos U8 32bit 192Khz equipped with two clocks of high precision allows this DAC to play High Definition files up to DXD 32bit 192Khz.
This DAC AK 4495SEQ also has Sharp and Roll Off digital filters that can be set by pushing on INPUT button.
Equipped with high-end components (LDO low-noise regulators LM2941, R-Core transformer), this DAC will quickly become a formidable link for any high fidelity audio system.
Caution : the RCA sockets mounted on the back panel are not supported by CANARE cables.
Main Features:
  • DAC AKM AK4495SEQ
  • SPDIF digital interface AKM AK4118
  • THD: 0.001%
  • Noise Ratio: 120dB
  • LCD display showing input resolution
  • Box 100% aluminum sandblasted with power button and selector in front
Inputs and outputs:
  • USB input XMOS up to 32bit 192kHz and DSD 64 in PCM but not in native
  • Coaxial S / PDIF Input 24bits / 192kHz Gold plated 24k
  • Toslink Optical Input 24bits / 96kHz
  • Analog Stereo RCA Plated Gold 24k
Dimensions and weight:
  • Dimensions: 261x190x62mm
  • Weight: 2.4kg
  • Power cable not included
  • Compatible with MAC OSX and Linux without driver, requires driver for Windows
DAC / ADC ChipAK4495SEQ
Max sampling rateDSD64
Max sampling rate192kHz
ColorSilver
8 reviews
De la matière sonore
Mes DAC sont de la génération Sabre ES 9018, la précision sonore était séduisante mais à l'écoute certains enregistrements étaient inécoutables. Ce DAC AKM, offre la définition, la profondeur des plans sonores , tout est là mais dans la fluidité, sans les duretés dans le haut du registre si désagréables sur des enregistrements médiocres. Donc, pour le prix il ne faut pas hésiter, les mélomanes seront contents. Pour information, il fonctionne avec un câble de modulation cuivre vendu par AUDIOPHONIC," sans marque", un ampli Audiolab de 30 ans d'âge et des enceintes KLIPSCH Heresy III.
This review has been posted for AUDIOPHONICS DAC AK4495SEQ 32bit 192kHz Asynchronous USB XMOS Silver
tres bon
c'est très bon.
La musique coule naturellement, a une résolution et dégage plus de musique dans plus de couches de profondeur. Comparé à mon multibit Schiit Modi actuel, l'audiophonique est clairement supérieur. C'était une surprise. Je ne m'attendais pas à autant de qualité audio à ce prix.
Très satisfait à tous points de vue (produit, service).
Pour le prix, c'est un très bon appareil. Je n'ai pas encore testé le changement d'AOP (pour du Sparkos) et reviendrais donc sur ce sujet.
Pour l'instant, une certaine "aggression" dans le haut medium est perceptible, ce qui, je l'espère, sera réglé avec le changement d'AOP.
Entretemps, j'ai cherché à comprendre le rôle de chacun des filtres dispos. Echec:
En effet, le vocabulaire employé dans l'article recommandé à la lecture par Audiophonics ne correspond pas au vocabulaire qui apparaît sur l'écran du DAC. Une correspondance des effets n'est alors pas possible.
Une aide est elle possible?
Merci d'avance.
EXCELLENT DAC FOR THE MONEY
Am really enjoying this DAC. It is a GREAT value for the price.
Bien pour un DAC moderne
Avant tout, concernant le service d'Audiophonics, c'est parfait comme d'habitude. Envoi rapide, soigneusement emballé.
Ma configuration: Lecteur CD Marantz CD6006 / ampli Marantz PM8005 / enceintes Focal Aria 906
Concernant le DAC,
Je désirais un DAC externe qui soit moins "agressif" et fatiguant que le DAC interne de mon lecteur CD. Après lectures, mon choix s'est porté sur ce DAC Audiophonics.
Coté construction, rien à dire. ça sent le sérieux en plus il est beau ce qui ne gâche rien.
Niveau rendu sonore, c'est bon mais pas trop.
Il n'est pas trop "montant" mais garde ce coté analytique des DAC moderne. Il est musical mais je trouve les Dac "Nos" encore plus musicaux.
En résumé, je dirais qu'il est inutile de faire la course technologique et vouloir a tout prix les dernières puces de conversion. On n'y gagnera qu'en transparence et détails mais pas forcément en musicalité.
