SMSL M2 USB DAC ES9023 24bit 96kHz Headphone Amplifier 130mW 32 Ohm Silver
Reference : 13570
57,90 €tax incl.
48,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
This nomadic helmet amplifier has nothing to envy the sedentary high-end of the market.
It is coupled to an ES9023 converter and an Asynchronous USB interface SA9027 to get the most out of your high fidelity audio sources.
It is equipped with an integrated amplifier MAX9722 for amplification.
This small concentrate of effective technology is above all pleasant and powerful.
Characteristics :
  • DAC ES9023
  • Interface USB 2.0 Asynchronous SA9027
  • Supports files up to 24bit 96kHz (including 88.2kHz)
  • Noise Ratio: 105 dB
  • Dynamic range: 110dB
  • THD + D: <0.003%
  • Frequency response: 10Hz - 48kHz
  • Supported impedances: 8 - 600 Ohms
  • Output power: 130mW at 32 Ohms
  • Output Voltage: 2Vrms
  • Power Consumption: <0.5W
  • Volume control
  • Mini USB port
  • Line Output / Optical Jack 3.5mm
  • Headphones Jack 3.5mm
  • Chassis Aluminum machined CNC anodized Black
  • Dimensions: 87x58.5x9.6mm
  • Weight: 55g
  • Supplied with: 1 mini USB cable A to USB-A
  • Compatible with ASIO, WASAPI
  • Color : Black
OutputJack 3.5mm
