HIDIZS AP80 Portable Digital HiFi ES9218P DAC 32Bit / 384kHz DSD aptX Bluetooth Black
With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player supports high sampling rates (Hi-Res) and Bluetooth aptX for more convenient use. Hidizs has integrated many features into its DAP for a pleasant user experience and a rich and detailed listening experience.
Reference : 13347
135,00 €tax incl.
112,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Hidizs AP80
DAP Digital HiFi Music Player DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Black
Hidizs AP80 Baladeur Numérique HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX
A clear sound, an incredible richness of sound
Crystal clear sound
Designed to deliver exceptional Hi-Res audio performance by accurately capturing and reproducing the depth of each note, the AP80 features an ES9218P DAC with an SNR of 126dB and a THD+N of -113dB.
HiBy OS
OS HiBy 3.0 is a music playback system recognized worldwide. This OS offers a premium musical experience, many settings and above all allows a very nice reproduction.
Mage Sound 8-Ball Tuning
The MSEB is a combination of several algorithms based on parametric equalizers and different adjustments to adapt the sound to your listening.
Un DAP Unique
Thanks to its many customization options, the AP80 is a truly unique DAP. Each user has the possibility to set the DAP according to his personal taste with for example more than 1000 colors available or the possibility to add the sound wallpaper.
Comparative table
Hidizs AP80Sony NW-A40
OSHiby 3.0 Linux VersionLinux
FMYesNo
Step counterYesNo
Sampling rate32bit 348kHz24bit 192kHz
DSD SupportDSD 64/128DSD 64
aptXYesNo
Screen size2.45" 480x360px Touchscreen3.1" Touchscreen
DACESS ES9218P-
Dimensions58 x 49 x 13.5mm55 x 97.5 x 10.9mm
ConnecticJack 3.5mmJack 3.5mm
Extensible storageMax 1TBMax 256GB
Battery capacity800mAhN/A
Quick chargeUSB Type-CUSB Type-C
A DAP to follow you everywhere
Bidirectionnal Bluetooth aptX
Using Bluetooth 4.1 and aptX technology, the AP80 allows high quality wireless transmission, similar to CD.
HiBy Link
For a more convenient use, it is possible to use the HiBy Link application to control the playback of your music directly from your smartphone. This method allows to obtain an optimal audio quality since it supports the Hi-Res Bit Perfect.
FM Function
Unlike most other DAPs, the Hidizs AP80 features an FM radio function that allows you to listen to your favorite radios in Hi-Res.
Step counter
With its on-board pedometer, the AP80 is able to count the number of steps you take when you run or walk. Ideal for sports to music.
A walkman that fits in the palm of your hand
Small size, high power
The design of this DAP has been designed to be extremely portable so that you can take your music with you anywhere and always in high quality. And if it is small, the AP80 is also powerful and its size has no impact on its performance.
2.45" Samsung Touchscreen
The Hidizs Walkman does not stop there and offers a superb 2.45" touch screen, allowing you to control the device with a simple touch.
New wheel design
The AP80 features a modern design, and incorporates a new volume knob with 3 physical buttons on the side, to easily control the DAP.
A significant autonomy
The walkman carries a large 880mAh battery under its shell, allowing it to be switched on for 15 hours in reading or 35 days in standby.
De nombreuses fonctionnalités
Bidirectional USB connection
The Hidizs AP80 integrates a DAC ES9218P with a bidirectional USB interface. This makes it possible to use the AP80 either as an ultra-high quality USB audio dongle for your smartphone, or as a digital source for other devices.
Hi-Res supported formats
Supporting the vast majority of Hi-Res formats, the AP80 will allow you to listen to your FLAC, APE, WMA, WAV, WAV, ALAC, DSF, DFF and SACD-ISO files. It also supports native 64/128 DSD and PCM sampling rates up to 32bit 384kHz.
Up to 1TB of storage
For storing your files, the AP80 can accommodate a Micro SD card up to 1TB. This way, you can store all your Hi-Res files for continuous listening.
Note: The AP80 has no internal storage and the Micro SD card is sold separately.
Clock
The AP80 displays a clock on its main screen. So you can travel listening to your favorite songs, while keeping an eye on the time.
" The AP80 is probably the best budget DAP I’ve ever touched and heard. "
Hardware specifications
CPUIngenic X1000
DACES9818P
ControlTouchscreen + Volume wheel
Internal stockageNo
Storage extension typeMicro SD card (sold separately)
Max storage capacity1TB
Connectivity
FMFM Radio
BluetoothBluetooth V4.1, aptX
USB InterfaceUSB-C, bi-directionnal DAC USB
InputUSB-C
OutputJack 3.5mm
Display
UIHiBy OS - Linux version
Screen size2.45"
Screen typeIPS
Resolution480x360px
Technical specifications
Sampling ratePCM 384kHz 32bit / DSD128
Output power2 x 75mW @ 32 Ohm
Frequency response+/-3dB 20Hz - 40h
SNR120dB
Dynamic range> 105dB
Channels separation105dB
THD+N0.003%
Output impedance< 1 Ohm
Headphone impedance8-300 Ohm
Lossless format supported.dsf, .dff : DSD64/128
.iso : DSD64
APE FAST/High/Normal : Max 24bit 192kHz
APE Extra High : Max 24bit 96kHz
APE Insane : Max 24bit 96kHz
AIFF : Max 32bit 384kHz
FLAC : Max 24bit 384kHz
WAV : Max 32 384kHz
WMA Lossless : Max 24bit 96kHz
Charging interfaceUSB-C 5VDC 2A
BatteryLi-Polymer 800mAh
Charging time< 1.5h
Autonomy15h
GENERAl
Housing materialInox / Aluminium alloy
Gain controlLow / High
Equalizer10 band equalizer (+/- 12dB), 8 presets
FiltersSlow descent
Sharp drop
Package Contents
USB-cable C to USB-Ax1
USB cable-C to micro-USBx1
Screen Protector Filmx1
Case (silicone)x1
Manualx1
AP80x1
InputMicro SD
OutputJack 3.5mm
DAC / ADC ChipES9218P
Max sampling rate384kHz
Max sampling rateDSD128
6 reviews
excellent baladeur
Installé dans une DS7 crossback comme bibliothèque musical.
Connecté en bluetooth, fonctionne très bien.
This review has been posted for HIDIZS AP80 Portable Digital HiFi ES9218P DAC 32Bit / 384kHz DSD aptX Bluetooth Black
bon rapport qualité prix
interface moderne, tactile et soignée : agréable et bien pensée.
Facile à utiliser, rapide pour se deplacer dans la bibliotheque
Possibilité de naviguer par dossier et sous-dossier.
Scan de la bibliotheque un peu long, mais pas plus que mon smarphone.
traduction française bonne, bons paramètres.
Volume ingénieux.
égaliseur manuel pas facile à régler et grosse baisse de sensibilité quand on l'active.
high or low gain output disponible
superbe écran, réglages luminosité, veille, theme de couleur, veille avec pochette.
Pas trouvé de négatif dans ce lecteur.
Magnifique
Suite à 1 utilisation « intensive », je peux le dire que c’est le meilleur DAP que j’ai eu jusqu’à présent... 1 merveilleuse expérience musicale pour 1 amateur de musique comme moi...
En tout point remarquable
Merci à Audiophonics pour son sérieux et ce à double titre :
– son écoute, sa réactivité devant la demande de ses clients ;
– la qualité de sélection des produits de son catalogue comme ce baladeur numérique.
Je e peux recommander que l'enseigne et cette marque au moins pour ce baladeur.
Bien à vous.
fabuleux ,heureux
comment expliquer que cet appareil vous fera vous coucher a des heures pas possible parce que le relier a votre casque c est entrer dans une autre dimension,le son est d une qualite phenomenale et vous fera redecouvrir tout vos albums avec une telle facilite qu il est quasiment impossible de s arreter tant le son est prenant et denué de toute agressivite.je possede un xduoo x 10 plus froid et dur dans les aigus,le hidizs est beaucoup plus agreable a utiliser, l interface est tres intuitive la radio est de qualite et le son en bluetooth et de tres haut niveau.bref un achat de qualite(utilisé avec casque denon ah d 600 et sony mdr 100 aap)c est l assurance de passer de tres bons moments musicaux.merci audiophonics et merci hidizs!!
With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance....
