FIIO X5 DAP / DAC Digital player Audiophile HiFi DSD 24 / 192Khz
FIIO X5 DAP/DAC Baladeur numérique Audiophile HiFi DSD 24/192Khz
4.0 / 5
By buying this product you get 37 loyalty points
Reference : 8550
379,00 €tax incl.
315,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
FIIO X5 DAC / HiFi Music Player Audiophile DSD 24bit / 192Khz
Upgrade of the Fii X3, the X5 is a very amazing device as comfortable as a walkman as a sedentary source audiophile.
Dual Usage: As a complete stereo (DSD / APE / FLAC / ALAC / WMA / WAV), it uses the PCM1792 converter which also allows it to be used as a PCM DAC USB (24B / 192K) and DSD.
Its amplification stage is composed of Aop and buffers (OPA1612 and LMH6643).
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_1.jpg
Characteristics:
  • Processor Dual Core CPU JZ4760B 600 mhz
  • DAC USB: PCM 192KHz / 24bit and DSD
  • Converter: PCM 1792
  • Helmets supported; 16 to 300 ohms
  • Analog output / headphone output: 3.5mm jack
  • Digital Output (Coaxial): 3.5mm Jack
  • Line Output: 3.5 mm Jack
  • Micro USB
  • Output Impedance: 0.22 Ω
  • Volume control: 120 levels
  • Right-to-left channel adjustment: 5 dB
  • Gain: 0/6 dB
  • Distortion Line: <0.0025% @ 1 KHz
  • Headphone output distortion: <0.003% @ 1kHz
  • Frequency response: 20Hz ~ 20KHz (+ / -0.1)
  • crosstalk:> 100 dB @ 1kHz 10kO
  • Signal Noise Ratio:> 115dB
  • Dynamic range:> 115dB
  • Line Output Level:> 1.5 Vrms
  • Power: USB 5V / 500mA recommended for USB 5V 1.5A
  • Battery capacity: 3700 mAH 3.7V lithium polymer
  • Charging time: 4 hours
  • External memory: 128GB max (64GB x 2) Attention no card delivered
  • Audio Format Supported: DSD, APE (192K / 24B), FLAC (192K / 24B), ALAC (192K / 24B), WMA (96K / 24B), AAC, OGG, MP3, MP2 ...
  • Screen: 2.4 inches / 400 x 360px Colors IPS
  • Three output interface: headphone output, line output, coaxial output
  • Housing: aluminum CNC
  • Power sources: USB port of the computer, USB power supply
  • Output power 1:> 475.8 mW @ 16Ω THD <1%
  • Output power 2:> 272 mW @ 32Ω
  • Output power 3:> 29 mW @ 300Ω
  • Weight: 200g
  • Dimensions: 67.6 x 114 x 15.6 mm
  • Comes with: Silicone case, coaxial adapter cable, charging cable
Photos of the conference for the presentation of Fiio x5
https://www.audiophonics.fr/images2/7890/7890_head-fi.png
center ">Topic on Head-Fi
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_2.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_10.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_16.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_4.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_8.jpg
Illustration with aFiio E12(sold separately)
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_3.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_13.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_14.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_compo.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_5.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_17.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_15.jpg
https://www.audiophonics.fr/images2/8550/8550_fiio_x5_baladeur_dac_hifi_dim.jpg
Pas mal du tout !
J'avais au départ l'intention d'attendre le x7 qui devrait sortir cet été, puis finalement je me suis décidé pour le X5.
Impression générale : La fabrication exterieure fait très solide, l'usinage et l'assemblage des pièces métalliques n'a pas de défauts c'est trés qualitatif pour le boitier. Un peu lourd peut être, mais cela ne me gêne pas. En revanche : les composants d'interface font cheap (écran, disque de sélection, boutons...). L'écran est défini mais les bandes noires sont pas top. Le disque.molette fait fragile, les boutons ont un clic très bruyant (laissez tomber l'écoute au lit avec votre moitié qui dort à côté, testé, ça passe pas !). Ces petits détails feront tiquer l'utilisateur exigeant, de même que l'ergonomie n'est pas hyper intuitive.
Tous ces petits défauts sont mineurs, et globalement le produit est suffisamment mature (firmware 2.4) pour parer à quasiment toutes les situations.
Quelques limitations : Si vous êtes un utilisateur intensif du DSD sous toutes ses formes, les DSF et DFF sont supportés, le son est superbe, mais clairement on sent que cela mets la machine à genou : l'ergonomie ne réponds plus au doigt et à l'oeil, voire peut se bloquer (sans aucun arrêt de la musique), pendant plusieurs secondes (même si c'est rare). Difficile de savoir si le DAC TI transcode en PCM ou pas mais la qualité est là, ça envoie!
Pas de support des SACD Iso (seul le Cayin N6 l'annonce ouvertement) pour le moment, fonctionnalité qui sera reservée pour le X7 visiblement.
Le deuxième limitation vient des ports MicroSD du x5 : ils sont lents! entre 7 et 9 Mo/sec, quel que soit la carte. Quand on veut remplir 128Go, c'est long, très long. Du coup il vaut mieux remplir la carte séparemment sur un lecteur externe, ou sur le dongle fourni.
La fonction DAC se configure facilement.
Outre ces petites critiques, qu'en est-il du son ? C'est vraiment très bon, la spatialisation est surprenante, rendu précis, nuancé. J'ai fait l'exercice de coomparer des écoutes via le x5 en DAC et via le U-SAbre d'Audiophonics version TCXO (équipé d'un Sabre 9023) et bien j'ai une légère préférence pour le X5, plus ouvert. Le ti Burr Brown qui équipe le X5 est bien mis en oeuvre, ça sonne bien. En revanche on sent bien que ces puces étant excellentes à tout niveaux, c'est vraiment les circuits autour et la mise en oeuvre générale des cartes qui font la différence. Le 1792A de chez TI équipe également l'Asus Essence STX sur PC, que je possède et qui fait partie de mon système de référence : le rendu y est quand même plus rond, plus équilibré, l'ouvertude semble encore plus ample. Attention donc à ne pas juger que sur la puce qui équipe un DAP ou un DAC.
Pour moi on est aisemment au nivau d'un Astell&Kern 100 AK100 II en termes de qualité de son pure (je préfère le rendu du X5), l'ergonomie et le rendu 'en main" est supérieur côté A&K
L'équalizer est vraiment puissant et même si je n'aime pas toucher en général à l'égalisation pour ne pas dénaturer le son, une légère compensation peut vraiment améliorer le rendu de certains intras. En tout cas l'équalizer est vraiment puissant et fin.
Le bundle est pas mal avec notamment un adaptateur pour une sortie coax numérique. Le coupon pour HD Tracks est par contre périmé...depuis mi 2014 ! Pas grave dans l'absolu.
Pour finir et la raison pour laquelle j'ai opté pour le X5 : la batterie. Une des plus importantes des DAP disponibles actuellement, on dépasse les 10-12 heures d'autonomie testée sans problème peut être plus selon le volume d'écoute. Sauf en DSD ! (on tombe plus vite, pas mesuré mais on doit être à 9-10 heure).
La possibilité de mettre 2x128 go de micro SD est super, d'autant que les cartes 256Go arrivent et seront supportées également. Les 128Go coutent entre 70 et 80 euros.
à 379€, une des meilleures autonomies dispo, un excellent son (le TI Burr Brown PCM1792A est excellent), gestion du DSD, capacité très évolutive du fait du double slot microSD. C'est tout simplement le meilleur rapport qualité-prix actuel.
C'est tout simplement un plaisir de commander chez Audiophonics. Merci à David et à ses équipes pour leur accueil à chacun de mes retraits de colis.
This review has been posted for FIIO X5 DAP / DAC Digital player Audiophile HiFi DSD 24 / 192Khz
