HIFIMAN HM-802S DAP / Digital Audio Player 24bit/192kHz POWER II
HIFIMAN HM-802S DAP / Digital Audio Player 24bit/192kHz MINIBOX Gold
By buying this product you get 74 loyalty points
10583
749,00 €tax incl.
624,17 € tax excl.
Accessories
The HM-802S is the evolution of the HM-802U.
It takes up most of the features of its elder with this time a conversion based on this time two Wolfson WM8740.
This DAP reproduces your digital files with incomparable sound quality, accepts the majority of audio formats and has a particularly intuitive interface.
It is a totally scalable player, allowing you to integrate different amplifier modules adapted to your music preferences and type of headphones.
Compatible amplifier modules:
Specifications HM802S:
  • DAC Wolfson WM8740 x 2
  • Supplied with the amplifier "POWER II"
  • THD: 0.008%
  • Frequency response: 20Hz - 20kHz
  • Audio Format Supported: WAV, AIFF, MP3, AAC, FLAC, APE, ALACLossless, DSD64 (DFF, DSF)
  • Noise Ratio: 110dB
  • Total Memory Max: 256GB (SD)
  • Analog volume control via step potentiometer
  • Gain: Low / High
  • 2 Headphone Jacks 3.5mm (Symmetrical / Asymmetrical)
  • Line Output
  • Battery life: 11 hours
  • Dimensions: 71x117x28mm
  • Weight: 250 g
  • Standard CE
Features Power II:
  • Output Voltage: 195mW
  • THD: 0.03%
  • Frequency response: 20Hz - 20KHz
  • Separation: 85dB
  • Signal Noise Ratio: 108dB
ComponentWM8740
StructureMétal
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
